obd port problem
obd port problem
Hey guys hope I can get a little help. I'm working on a friends 94 camaro and went to tune it for him but I got no comunication with the pcm. Thought it was my laptop or cable but tested with a scaner at work and same thing. Even tryed a hyper tech programer that will turn on when you plug it into the obd port but then says no comuication, check cable. So I'm thinking its one of the wires from the port to the pcm guess I gota brake out the multimeter...................
Re: obd port problem
thats what i thought but i thought it was weird that the hypertech turns on when you plug it it poss triggered by ground? oh well now its time to start checking wires. thanks guys
ok so pin A is ground. pin B is diagnostic request. pin g is program imput, keyless entry receiver. and pin m is seral data line.key off I have ground on pins A,B,M and 7v on pin g.KOEO I have ground on pin A, 7 volt on pin G, and 4.9v on pins B and m. anyone know if thats all right? seems like it. Im not thinking a damaged wire anymore but a damaged pcm now.
If his 94 Camaro has the A4 trans, there will be a mismatch with the TC lockup signal from the the 95 PCM (on/off in the 94 vs. pulse width modulated in the 95).
10-31-2016 11:09 AM
oldschool
02-09-2016 09:21 PM
