Output Driver Module Fault
hello, Serg here, I recently bought a 1995 camaro z28 with the T-56 and I hooked up a scan tool just to see what it would read and it said "Output Driver Module Fault" and also said DTC#29. The car runs normal and I would just like to know what a ODM is and what could be wrong with my car.
Any help would be great. Thanks
Thanks, I checked the fuse and it was bad, I replaced it,erased the codes, and scanned it again and it still shows the same thing: Output Driver Module Fault I have no idea what that means. thanks again for helping me out
You don't need to know that that means, because it is not the right definition. Again, look at the code descriptions on my Tech Page. Check the fuse again, maybe it blew again-meaning the AIR pump is probably seized up.
dluna333
15
03-13-2015 12:30 PM
07-04-2005 05:00 PM
