lt1 runs on ls1 computer using modded OPTI
got the car running on the ls1 computer today... i repinned the lt1 harness into the connectors and addded the in the coil wires and made a custom wheel for the opti.
i was worried at first as it would barely stay running then i pulgged in the other coil harness and it runs like a champ now..
dont mind the smoke there was some antifreeze on the downpipes.
http://www.youtube.com/watch?v=btAtQtIe3LY
there is also a air tight cover that goes on that opti and..
Always thought that would be the easiest way to do it:
https://www.camaroz28.com/forums/sho...5&postcount=24
Glad you demonstrated that it could be done.
well my inital post was a over simpilfication. i had to modify the optical portion of the sensor to output 12v instead of 5v. other than that it was pretty straight forward.
