Confused on code
Old 09-01-2012, 07:32 PM
jloshotz's Avatar
Confused on code
Anyone know what a code 61 is exactly on an OBD1 car? Thanks in advance
jloshotz is offline
Old 09-01-2012, 09:36 PM
Re: Confused on code
See Shoebox's LT1 code list:
http://shbox.com/1/Dtcs.htm
Basically, low AC system pressure due to low R134a.
Injuneer is online now
Old 09-02-2012, 06:49 AM
jloshotz's Avatar
Fred, I did see that, I never had that one come up before, and have had my a/c down before. I didn't even think the PCM cared one way or another about the A/C system on OBD 1. It's strictly an A/C dtc?
jloshotz is offline
Old 09-02-2012, 09:10 AM
Unless they changed the code from 94 to 95 (I have a 94 shop manual) it's specifically for the AC charge level.
DTC 61
A/C SYSTEM PERFORMANCE
5.7L (VIN P) "F" CARLINE (SFI)
Circuit Description:
The PCM monitors A/C refrigerant pressure and A/C evaporator temperature to determine if the A/C system has adequate refrigerant (R134a) charge. The PCM will disable the A/C clutch whenever the refrigerant charge drops below a predetermined value, to reduce the chance of compressor damage. The PCM will cycle the compressor more frequently if the charge is only slightly low......
DTC 61 Will Set When: The PCM calculates refrigerant charge to be below a predetermined level.
Action Taken (PCM will default to): If the PCM determines A/C refrigerant charge to be low, the A/C clutch will be disabled and DTC 61 will be set. DTC 61 will be stored in the PCM memory, but will not turn "ON" the Malfunction Indicator Lamp (MIL).
Old 09-02-2012, 09:13 AM
jloshotz's Avatar
Interesting, thanks Fred! I am definitely undercharged at the moment, didn't think OBD 1 was advanced enough for that, glad that's all it is
jloshotz is offline
lildemars09
05-28-2015 07:54 PM
warmeck
05-07-2015 02:10 PM
johnsocal
08-29-2002 10:01 AM
Darth Xed
14
08-07-2002 12:21 PM
91Bird305
08-05-2002 01:39 PM
Quick Reply: Confused on code
