Best way to run a datalog scan?
Re: Best way to run a datalog scan?
Depends on what problem(s) you are trying to solve. For general purposes, run a complete log - start it cold, let it warm up and enter closed loop (should take about 3-1/2 minutes), drive it normally under a wide variety of conditions, including a couple WOT pulls (in a single gear, no need to run it through the gears), stop and let it idle for 30 seconds. I've received logs for review running anywhere from a minute to 30 minutes. You should be able to cover most everything in a 10 minute period.
Sixer-Bird
10
08-25-2002 01:12 AM
