Best PCM to use with LSx Swap
Not sure if this is the right place to post this question, please accept my apologies if I should have posted elsewhere.
We are building a drift car and have a built LS2 ready to go in. The chassis was originally a Nissan 240 but all the original wiring is pretty much gone. We have been told that the best option (in terms of price) is to get a camaro PCM and harness to run the LS motor.
I'm familiar with the basics of SD tuning (with a 92 Corvette / boosted LTx motor) but not so much with MAF tuning.
So - what year PCM/Harness would you guys recommend? The motor is around 550 at the crank NA, so we'll also need to make sure the MAF is big enough and the PCM tables can deal with that kind of airflow.
Thanks!
Thanks!
Re: Best PCM to use with LSx Swap
Since we already have a LS motor, all we need is a PCM and harness. We will run a standard throttle body (i.e. not 'by wire'), so I'm assuming that any 97 thru '04 LS PCM will work - including Silverado, Camaro.. etc.?
One of the reason's I'm asking about a vehicle specific LS PCM is we have access to a lot of used car parts (and we can also get new parts at dealer cost).
The question is simply if I am going to get a used PCM, which one would be the best starting point for my LS swap. Thanks!
Hotrods&Muscle
01-28-2015 09:35 PM
Hotrods&Muscle
12-21-2014 03:57 PM
