anyone have a 1996 Z28 A4 - Stock tune file
Does anyone have a stock tune file (unmodified - like an original back-up) for a 1996 Z28 (LT1) with automatic trans? I am using JET (formally tuner cats) to read/write the PCM. When I got the car the PCM was laying against the firewall and the mounting tabs are broken so I am thinking that I may have a bad tune problem (VIN of the PCM matches the car).
I am currently getting a lot of knock retards through the rpm range. I have been logging and pulling timing out and she is starting to really perk up but I just wanted to rule out possibilities of alternate problems.
thanks in advance if anyone has one!
Re: anyone have a 1996 Z28 A4 - Stock tune file
If none here has one, you could try over here.. OBDII Tuning
01-05-2015 07:14 PM
Brandon Wittmer
12-03-2014 09:28 PM
