94 Z28 high idle - CamaroZ28.Com Message Board
Reply
Thread Tools Search this Thread
Old 04-28-2012, 11:22 PM   #1
94 Z28 high idle
I am having trouble with high idle concerns, it's at a shop, they think it's the lack of smog pump causing the high idle, I think not, could be wrong, also when you unplug the map sensor it doesn't effect the idle at all.....any help would be appreciated....don't know much bout the car, got it cheap, replaced,optispark,waterpump, coil, and thermostat..
gregory55fan is offline   Reply With Quote
Old 05-01-2012, 10:56 AM   #2
Re: 94 Z28 high idle
Removing Air Pump and pipes correctly (plugging manifold ports and snorkel port) will not cause high idle. High idle can be caused by Vacuum leak, TB linkage sticking, TB set screw maladjusted (blades opened to much), Coolant Temp sensor defective or incorrect tune (desired idle speed setting). Are the fans running constantly ? High how is your idle ?
bobdec is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
1996 Chevy Camaro Z28 SS w less than 19k org. miles F'n1996Z28SS Cars For Sale 6 04-02-2015 11:02 PM
Throttle Position Sensor (TPS) A's 91 Z28 Fuel and Ignition 1 01-11-2015 11:58 AM
Hesitation off idle IRABuss LT1 Based Engine Tech 445 09-07-2011 10:08 PM
Rockford RFX9300 head unit having problems!! slothgrant Car Audio and Electronics 0 08-22-2002 04:01 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
