OIl presssure fluctuation/valve tap/vibration=???
Old 05-26-2008, 10:30 PM
unstable bob's Avatar
Thumbs up OIl presssure fluctuation/valve tap/vibration=???
OK, engine in question is a small block, .030 over, decent hyd cam. Started out having a valve tap. Oil was changed, valve tap still present. Now oil pressure gage goes nuts while at cruising speed, is bouncing between 50-60 lbs. Has a fairly steady 30 lbs pressure at idle. And now there also seems to be a vibration right before shifting up to next gear. Any ideas?
Thanx,
ubg
unstable bob is offline
Old 05-28-2008, 10:20 AM
Rice Killer87's Avatar
Oil pressure moving around could be a loose or fallen off pick up in the pan.
Vibration hard to tell,maybe loose convertor bolts?
Rice Killer87 is offline
Old 05-29-2008, 07:05 PM
go2fast's Avatar
Or the pickup is too close to the bottom of the pan.
go2fast is offline
Old 05-29-2008, 08:35 PM
gnomee's Avatar
Don't mean to sound stupid but check the oil sensor / gauge. You could be chasing your tail on something like that.
gnomee is offline
RX Speed Works
07-24-2015 02:25 PM
big_mac421
07-13-2015 03:48 PM
jl1ne
07-07-2015 08:38 PM
streetbad
Advanced Tech
07-05-2015 10:40 PM
SergheiS
07-05-2015 03:27 AM
Quick Reply: OIl presssure fluctuation/valve tap/vibration=???
