Where to decode bog block serial number?
Old 07-21-2002, 02:41 PM
Timberwolf's Avatar
Post Where to decode bog block serial number?
Looking to decode the serial number on my block. It's: CGJ1107CC
Anyone have a book or can point me here to look?
oops..too bad you can't go back and edit the title on these...maybe I should start proofreading
[This message has been edited by Timberwolf (edited July 21, 2002).]
Timberwolf is offline
Old 07-21-2002, 03:07 PM
Another Red Z's Avatar
Post
1969 CJG Camaro 402 325 TH L-35
1101 is the month 11=November 01=first day of the month.I got this info from http://www.nastyz28.com/sbchevy/sblock.html not sure wht the CC means.
1994 Z/28 M6 t-tops not stock
1970 RS Camaro 383/th350 4.10's
1987 C20 parts hauler/beater
Another Red Z is offline
Old 07-21-2002, 05:31 PM
Timberwolf's Avatar
Post
hmm, well mine is CGJ, and if I'm reading the decoders right, it says they go by the suffix which is CC. Thanks though.
Old 07-22-2002, 03:16 PM
Jeff H's Avatar
Post
Are you reading the code stamped into the block on the front pad by the cylinder head? If so, that sequence doesn't make sense. It should be something like 'T1107CGJ' and then maybe the car's partial VIN stamped up there as well. Are you sure it's a big block and not a small block? What's the casting # and casting date of the block? I found several CGJ and CJG if that's the code. I found CCA, CCC and TCC for engine codes, but no reference to just CC. Check the stamping again and get the casting information and that will help us figure it out.
Jeff.
Jeff H - 69 Z28 Hugger Orange, GM crossram, GM fiberglass cowl induction hood, factory TI setup & factory installed JL8 4 wheel disc brakes - original #'s matching and documented, being restored), 87 Toyota 4Runner SR5 Turbo
Jeff H is offline
Old 07-22-2002, 08:13 PM
Timberwolf's Avatar
Post
well, it's DEFINITELY a big block, I've been around chevy motors for 20 years or so.
As far as the rest of the serial number, that's all I can get. The last C could even be an O, I'm not sure. It is worn off from that point on.
Trying to get a casting number, but it's nearly impossible to see since the wiper motor is right in the line of site.
I can get the one from the intake, but that will just tell me it's a big block, which I already know...
Old 07-22-2002, 08:32 PM
Jeff H's Avatar
Talking
Just wanted to make sure it was a big block. Any chance it's CE at the beginning of the sequence? A CE block is an over the counter or warrany replacement and they get some strange codes stamped into them. The casting date will still help the most in trying to identify what year vehicle it came from. I'll check around some more. I think all big blocks came from the Tonawanda plant and should begine with a T.
[This message has been edited by Jeff H (edited July 22, 2002).]
Jeff H is offline
Old 07-22-2002, 09:11 PM
Timberwolf's Avatar
Talking
ok, I pissed my self off, so by flashlight, I went out and yanked the distributor. I get the following casting number:
14015449
I have found 1401544 and that came back as 454 truck block
Also found 14015443 which showed a 87-90 4 bolt block, MK IV truck or motorhome
Also found 14015445 which showed 78-90 2 or 4 bolt
Intake manifold is 3883948 which shows either 396 L-35 or 427 L-36
This jive with what you guys have? anything more specific on the block number?
As a side note, I am grinning about it possibly being the larger rat ...
Old 07-23-2002, 03:48 PM
Jeff H's Avatar
Post
With that casting #, I would think it's probably a later 454 then. Don't pay much attention to the intake since they can be swapped around.
Jeff H is offline
F'n1996Z28SS
08-23-2023 11:19 PM
RUENUF
05-25-2016 08:10 PM
RUENUF
03-13-2016 03:39 PM
MadMav
02-06-2015 11:02 PM
Quick Reply: Where to decode bog block serial number?
