Help with Measurement in Engine Bay
I have a 72 SS, I took the front clip off before making a key measurement.
If anyone out there has a 70-73 Camaro with 350-4bbl, I need the following dimmension. Appreciated.
Distance from the Long block (where intake manifold mounts) just above the Cam to the Fender line. Basically, I trying to find the clearance to determine whether i can use a standard hood (preferred) or a cowl hood.
If you put a level across the fenders and measure up from the long block, I can go from there.
Many thanks.
Wolfpack77
Many thanks.
Wolfpack77
alex5366
03-08-2015 11:32 AM
formula218
12-02-2014 04:27 PM
Caps94ZODG
22
07-30-2002 08:45 AM
