Do I need 7/16 or 3/8 studs; 327 ; r. rockers - CamaroZ28.Com Message Board
Reply
LinkBack Thread Tools Search this Thread
Old 01-31-2006, 02:25 PM   #1
AlwaysCode390's Avatar
Exclamation Do I need 7/16 or 3/8 studs; 327 ; r. rockers
I am going to get a set of roller rockers for my 327 and dont know if I need 3/8 or 7/16 studs. Thanks!!!---
AlwaysCode390 is offline   Reply With Quote
Old 01-31-2006, 02:28 PM   #2
IHI
IHI's Avatar
Re: Do I need 7/16 or 3/8 studs; 327 ; r. rockers
With the can type and specs you listed in the other thread you started, 3/8" are PLENTY strong. Typically you wont need a 7/16" stud until you start getting into big lift roller type cams that use high spring pressures and tend to deflect valvtrain components. You application is very simple and "cut and dry" nothing exotic needed until you step up the entire valvetrain.
IHI is offline   Reply With Quote
Old 01-31-2006, 02:43 PM   #3
SO the 3/8 will fit with my older valvetrain right? As far as I know the heads are all stock besides the "302" z28 gm springs were added to compensate for the 222/222 .447/.447 114lsa cam I have. The stock stud is 3/8? ---
Old 01-31-2006, 02:58 PM   #4
IHI
IHI's Avatar
You'll have to tap the threads and depending on heigth may require area stud will bolt into to be cut down as well, otherwise rocker might no even be close to matting with the valve stem.
Old 01-31-2006, 03:40 PM   #5
So you say the stock stud is 3/8 that I have already installed , and if I want to go to 7/16 (not even needed for me ) I would have to pull out the old ones and tap for the new ones? Thanks---
Old 01-31-2006, 04:13 PM   #6
no,its going to be the stud on top,both the 3/8 and 7/16 will screw in,its the part that sticks out thats thicker.
if your starting from scratch go with 7/16,why not,price the same
if you got 3/8 already stay there,like he said unless your totally radical 3/8 is fine for most street.
your 3/8 rockers wont fit 7/16th studs and vice versa
anthony714 is offline   Reply With Quote
Old 01-31-2006, 04:13 PM   #7
Old 02-03-2006, 11:04 PM   #8
Stephen 87 IROC's Avatar
Standard SBC rocker studs are 3/8". As mentioned above, a 3/8" rocker for you will be fine. My old 383 stroker used 7/16" stud rockers. To do this with a stock head that has pressed in rocker studs isn't recommended. If you have spring pressures high enough that you need a 7/16" stud, chances are you'll pull it out of the head.
If your heads have been machined for screw in studs, you just need a conversion stud to use 7/16" rockers. The thread hole in the head is still 3/8" so the head doesn't need to be modified. The top part of the conversion stud is 7/16". If your heads still have pressed in studs, they can be removed and the stud boss can be machined down and tapped for screw in studs.
Gen V BBC engines are the same way. From the factory they use a 3/8" stud, non adjustable, valve train. All other BBC engines use 7/16" stud rockers. To convert to 7/16" stud rockers so you can use normal aftermarket parts and convert to an adjustable valve train, you simply buy the conversion studs. Unscrew the factory studs, screw in the conversion stud and install any aftermarket BBC rocker. Normal BBC rocker studs have 7/16" top and bottom but they also see much higher spring pressures than most SBC engines.
If your SBC engine gets over 200 pounds seat pressure on the spring which means about 600 pounds open pressure, you may consider getting the stud holes in the heads retapped for 7/16" and use BBC rocker studs.
Stephen 87 IROC is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
Lt1 parts..cam/rockers..etc 13qtr Parts For Sale 24 10-28-2016 09:11 PM
1.6 RR pre-load adjustment questions 9t4lt4z28 LT1 Based Engine Tech 1 10-02-2015 11:28 AM
383 lt1 swap Z Power LT1 Based Engine Tech 8 09-20-2015 12:19 AM
Goofy spedometer mmf_1013 General 1967-2002 F-Body Tech 0 09-12-2015 09:56 PM
1980 Z28 Camaro for sale Daluchman1974 Cars For Sale 1 09-11-2015 07:12 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
