Deuce deuce
Re: Deuce deuce
Steering components
1. tie rod ends (there are four, inner and outer on each side) should be removed and inspected. The studs may be loose, holes worn, etc.
2. idler arm (there is one)
3. steering box (there is one) and it has minimal provision for adjustment
4. drag link (there is one with no moving parts but it is susceptible to wear in the mounting holes
5. steering knuckles (one on each side)
Suspension components
1. Upper and lower ball joints (one of each on each side)
2. Loose or non functioning shock absorbers (one on each side)
3. Upper control arm bushings (two on each side)
4. Lower control arm bushings (two on each side)
5. steering column rag joint (there is one)
When it's all done, the car will need to be completely realigned.
When beginning to reclaim an older car, inspection and replacement of all the above is one of the first orders of business. Labor is fairly extensive but if you do it all yourself, you'll be able to put that money in your pocket and you'll know a LOT about your car when the job is done. Many of the requisite tools can be accessed through parts stores such as AutoZone or O'Reilley's on a rental or loan basis. If you just beginning in this sport, you may wish to buy some of them. If you live in Southern California, PM me.
Good luck,
c
