Break in question...
Old 11-25-2008, 10:40 PM
81z28phil's Avatar
New motor, So eh whats the proper way to break it in?
81z28phil is offline
Old 03-01-2009, 08:28 AM
doc221978's Avatar
Street or race engine?
For the street I keep it between 1,500-200 rpm's for about 15 minutes then drive it light for around 2-3,000 miles.
Depending on the type of race engine..... drag has no break-in, and endurance engines I run it at 3,000 rpm's for 30 minutes.
You can get 20 different answers from 20 different people though.
doc221978 is offline
Old 03-02-2009, 10:28 AM
Z28SORR's Avatar
Well, there didn't used to be 20 different answers. Initial break-in on a "classic" engine is for the flat tappit cam. After coating the cam lobes and lifters with assembly lube, start and run the engine for at least 20 min. at ~ 2000rpm. After that, final tuning is done and then you can drive it. Used to be that 500m., at varing rpm, was concidered enough for proper ring set-in. This should be done with "high zinc dino" oil, like racing oil or bike oil. Nothing wrong with longer break-in times, but I have never seen any Data that indicates it is necessary. After that change the oil and filter, with your choice.
Z28SORR is offline
93 RedBird
11-15-2015 08:24 AM
Bxlt1
09-29-2015 03:18 PM
08-17-2015 09:50 AM
Cam's maro
08-11-2015 07:45 AM
Quick Reply: Break in question...
