79 z28 shifter probs
Old 02-01-2014, 08:11 PM
Deuce deuce's Avatar
got a hurst shifter in my z not working correctly look under the cable to tranny is looped that is a straight run right that should not be looped right (advise)
Deuce deuce is offline
Old 08-25-2015, 09:31 PM
kylekratzenberg's Avatar
Re: 79 z28 shifter probs
I had the same problem In my 79 Camaro too. Check to make sure you're running intake vacuum not ported vacuum off the carb if that's not it get the Trans into first gear or park and adjust the cable that way also make sure your detent is hooked up and adjusted correctly good luck!
kylekratzenberg is offline
F'n1996Z28SS
08-23-2023 11:19 PM
karpetcm
02-09-2015 09:21 PM
tds1213
11-27-2014 12:55 PM
BIGCOWL-IMP
11-21-2014 09:40 AM
Quick Reply: 79 z28 shifter probs
