640HP Smallblock
Old 02-09-2014, 10:02 PM
Steve69SS396's Avatar
640HP Smallblock
Finally ran my motor on the dyno. I'll be dropping it in next week when the converter arrives.
Steve69SS396 is offline
Old 02-17-2014, 11:04 PM
Re: 640HP Smallblock
Old 03-07-2014, 10:53 PM
Everything on this new motor is different and needs to be modified. Would have been driving the car weeks ago if I had just dropped in my old setup. But that wouldn't have satisfied my need to go faster.
My electric fans have been on backorder for several weeks. Once those arrive I still need to mount the catch can for the radiator, catch can for the vacuum pump, pickup my new hood, have the exhaust welded up and re-wire the nitrous. I've had a progressive controller on my nitrous but always ran it at 100% because the car dead hooked. May need to actually use the controller with this motor.
Until then, here's another video of it running in the driveway.
Old 04-06-2014, 09:19 PM
Everything is all buttoned up. She's ready for some motor passes next Saturday. I expect it should run 10.20's maybe better. I would be shocked and real happy if it ran a 9.90.
Old 04-12-2014, 02:51 PM
Kevin Blown 95 TA's Avatar
It sure looks like you didn't spare any expense. Be sure to post up after you try it out. That cam sure sounds raunchy, What is it?? Is that duration really at .050?
Kevin Blown 95 TA is offline
Old 04-12-2014, 04:07 PM
Thanks! Here are the specs on the cam:
Old 04-12-2014, 06:56 PM
Good grief! That is a lot of duration. I was trying to see how high it was revving in the video, but I couldn't really see the numbers. Good job on building a killer small block 427. That's the best one I've seen in a while. Good luck at the track!
Old 04-13-2014, 01:43 PM
Thanks! I planned on going to the track yesterday but Sacramento Raceway canceled Test n Tune because they had a private track rental going on. So I swapped the slicks for my other rims with 28" X 14.5 Hoosier QTP's and drove it around.
Old 04-20-2014, 01:03 PM
Made it to the track yesterday! It ran 10.40's at 128 on the motor with sixty foot times in the 1.50's. It was dead hooking but would bounce when I got aggressive off the line. Time to replace the $15 Kragen shocks in the rear and Comp Engineering shocks up front.
Steve69SS396
Track Kill Stories
15
08-10-2015 02:45 PM
Z284ever
62
03-09-2005 08:54 AM
Z284ever
01-11-2005 01:47 PM
stonedchihuahua
3rd Gen / L98 Engine Tech
07-15-2002 05:07 PM
Quick Reply: 640HP Smallblock
