Windows and Radio
Windows and Radio
I was working on the drivers window (working spardically) and think I may have shorted something out while testing for voltage at the switch terminals. Worked fine for a bit and now both windows and radio will not work. I read about the RAP module might be the problem but form what I read, the RAP controls other interior lights and they all work fine. Any one have any suggestions?
Re: Windows and Radio
edit your sig. what year is your car what do you have done to it ?up until 94 there is a module only for the rap or retained accessory power. after that it is built in with the bcm this allows for use of the windows and radio until a door is opened sounds like a good starting point for you to look check fuses the body control module powers the lights not the rap
Bigfatrat
Parts Wanted
10-16-2015 04:48 PM
z28cam1993
09-09-2015 04:08 AM
