Will 94-96 door lock switches work in a 93?
My 93's driver side door lock switch broke. I realize that the 93s have a yellow print on them as opposed to the white print on the 94-96, but my main concern is will it work? The part numbers for the 94-96 are:
10402836 LH
10402835RH
Thanks in advance.
10402836 LH
10402835RH
Thanks in advance.
Re: Will 94-96 door lock switches work in a 93?
I'll answer my own question so that folks doing a search can find this. YES, all power lock and window switches are interchangable for 93-97 cars regardless of their part number. I used a switch from a 96 Camaro in my 93 and it worked fine. It's a different color (mine is gray with yellow font and the 96 is black with white font) but it works perfectly.
