Lots of problems 94 camaro
Old 07-06-2016, 10:35 AM
Mexicutiioner's Avatar
I bought a 94 camaro with a v8 a week ago and the car has been parked inside a garage for 5 years, the day i got it it turned on nice and smoothly, i drove it home and around town ever since yesterday i took it to jiffy lube get a oil change, from there i went to autozone to buy spark plugs and when i pulled out the car started loosing power and died, now its not running, i turns and i can hear the starter working and in some points the engine runs but then dies seconds after, my dad suggested it could be the fuel pump but i cant get access to it, anyone got any suggestions???
This is one of the major problems, the other ones is that the passenger window buttons dont work, the entire car s alarm system doesnt work, the key button thing to unlock and lock and unlock the trunk dont work either, the driver side door split in hald so now when it rains water gets in because the window is out of place
Mexicutiioner is offline
Old 07-06-2016, 11:45 PM
Fatdog2's Avatar
Re: Lots of problems 94 camaro
Bad gas.Might change the gas filter.It's near the drivers side rear axle area..Check your fuses on the left side of the dash.Hope this helps.Get a hold of a repair manual.Do a search on this website for some answers.This might be a long shot but did you check the new oil level from jiffy?My old neighbor brought his ford 4 wheel drive to jiffy for a rear end oil change and they forgot to put new oil in.Rear end froze up 5 miles down the road.They bought him a near rear end.Hope this helps.You might google for what to do when a car has been sitting for years.My02.( the coil wire may have slipped off or may have become corroded).
Fatdog2 is offline
Old 07-06-2016, 11:47 PM
Fatdog2's Avatar
Battery?
Fatdog2 is offline
jayblev95
06-07-2015 04:04 PM
adam85
Parts Wanted
05-20-2015 10:50 PM
blkWidow
05-03-2015 08:42 AM
kirschman
05-01-2015 10:40 PM
4586
04-24-2015 01:03 PM
Quick Reply: Lots of problems 94 camaro
