location of factory amp
Old 11-22-2005, 07:02 PM
kadoi's Avatar
i have a 95 trans am. first off how do i know if it came with the monsoon or bose system? it has tweeters and 6.5's in the front 6.5's in the passenger mounts and 3.5 or 4 inch in the back with tweeters. the factory stereo also had the equalizer with it. would this set up come with a factory amp and if so where? any input is much appreciated.
-cory
kadoi is offline
Old 11-22-2005, 10:21 PM
CamaroBoy96Z28's Avatar
Re: location of factory amp
If its premium sound in a 95, you're looking at Bose. I have a factory sub on the driver's side in the trunk which was a dead giveaway. Each of my speakers has its own amp and then an amp for the sub too. Either way theres nothing that needs to be done with the amps anyway unless you're replacing equipment.
CamaroBoy96Z28 is offline
Old 11-23-2005, 12:00 AM
stroked383z28's Avatar
The pontiacs did not come with the bose system. If it is a monsoon system it will say monsoon on the head unit. Either way there should still be an amp behind the spare tire.
stroked383z28 is offline
Old 11-23-2005, 09:58 AM
johnnyb's Avatar
you have the premium 10 speaker sound system for 1995. there was no monsoon option i believe. the amp is under the plastic by the back passenger seat, not the spare tire well
johnnyb is offline
Old 11-23-2005, 04:37 PM
Monsoon was an option starting in 95.
RUENUF
05-25-2016 08:10 PM
RUENUF
03-13-2016 03:39 PM
meissen
06-01-2015 07:59 AM
Chet1185
Parts Wanted
03-15-2015 04:29 PM
97QuasarBlue3.8
07-22-2002 09:09 AM
Quick Reply: location of factory amp
