Location of breaker for Rear defroster 95 Z28
Old 10-29-2011, 08:36 AM
Psycho's Avatar
Hi. I am trying to find the location of the rear defroster breaker. Mine only stays on for 10-30 seconds. The fix for this is supposed to be replacing the relay with a fuse. OK, but where is the breaker?
95 Z28. thnx
Psycho is offline
Old 10-30-2011, 04:04 PM
BandDirector Blk98ZM6's Avatar
Re: Location of breaker for Rear defroster 95 Z28
It should be in the fuse box inside the car...there's where mine is in my '98...
BandDirector Blk98ZM6 is offline
Old 11-01-2011, 10:22 AM
silv95z28's Avatar
i have the exact same issue with mine. i need to look into that
silv95z28 is offline
Old 11-06-2011, 03:52 PM
It is a common issue. A 30A fuse solved my problem in my '98.
Old 11-12-2011, 04:30 PM
L.dookie's Avatar
it's the only circuit breaker in the fuse panel inside the car. left side of the dash. the one you see when you open the drivers door. should be the only thing that doesn't look like a normal fuse.
L.dookie is offline
siguy
11-27-2014 10:07 AM
squarehead
11-21-2014 08:02 PM
PaulN64
08-08-2002 05:39 AM
30thZ286speed
08-03-2002 04:54 AM
Wilson
07-21-2002 04:58 PM
Quick Reply: Location of breaker for Rear defroster 95 Z28
