found side speakers
found side speakers
my car originally came with the 3 speaker delco bose system but while i was scrap yard digging today i found a camaro with the 5 speaker system but having only the speakers right behind the seats left. is it possible to hook these up to my 3 speaker system if they still work? i have an aftermarket stereo in however tho
why dont you put a sig with what car you have? If you have a aftermarket radio, you can definately run speaker wires to the speaker location if its not already there (most of the time the wires are there just tucked up).
I was actually unaware there was a 3 speaker Bose setup...
Do you have sail panels with speaker grills in them?? If not you should pull off the sail panels and just make sure the speaker holes are in the metal behind the sails. I would also just run new wires to the speakers. If there is wiring there, which I would doubt, as the Bose system is amped at each speaker, so why would they include the amps?? And the Bose wiring is different than standard wiring, so I doubt the wires would be properly setup in the harness.
But yeah running new wires is fairly easy and if the speaker grills / mounts are there you're all set.
cmsmith
04-11-2015 09:37 PM
