Driver Side Power Window wont go up Help ASAP PLZZ
Old 04-20-2013, 05:13 PM
V8 LifeStyle's Avatar
Pressed the window down button (Driver side) and the button broke off, so i bought a new master switch. Passenger side goes up and down perfect, I checked with a test light the driver switch and all checks out fine on the switch,, then I took the door off and checked the plug that goes into the motor and the test light only lights up when i hit the down button. So I went and tested a new window motor same thing doesnt work, then swapped the Power Window Control Module on it from a buddys z28 that both windows work and nothing. Window still stuck, what could be the problem?
Thanks guys
V8 LifeStyle is offline
Old 04-20-2013, 06:39 PM
Re: Driver Side Power Window wont go up Help ASAP PLZZ
You need to add info, like the year of the car.
Injuneer is offline
dale3in98
02-14-2015 12:18 PM
capebuf
01-13-2015 07:22 PM
cmdeshon
Parts Wanted
12-16-2014 07:58 AM
siguy
11-27-2014 10:07 AM
squarehead
11-21-2014 08:02 PM
Quick Reply: Driver Side Power Window wont go up Help ASAP PLZZ
