Dash, Tail, Fog, and Interior Lights Not Working
Old 11-09-2012, 04:17 PM
Misfit74's Avatar
1995 Pontiac Firebird Trans-Am.
Problem: Dash lights, tail lights, fog lights and stereo don't come on and neither do the dome and other interior lights.
Headlights raise up and light properly.
Fog, tail, and parking lights flash on when arming the alarm, as usual. I've had the alarm checked and ruled out.
Other notes: HVAC works, fans blow, but panel doesn't illuminate. Glove box light doesn't work. Interior lights on doors don't work.
Power windows and locks work fine.
Fuses at interior panel and engine compartment fuses and relays have been checked. None were blown/bad.
How do I fix this or what should I check?
Misfit74 is offline
Old 11-09-2012, 05:44 PM
parkers Z28's Avatar
Re: Dash, Tail, Fog, and Interior Lights Not Working
any Corrosion on the fuse block under the hood? a few week ago some on else was having some of the same problems
he said that the BCM had a crack in it and that was( his problem ) you need to find out were the
power loss starts I think shoebox has the wire diagrams ??
parkers Z28 is offline
Old 11-09-2012, 07:06 PM
Misfit74's Avatar
I got help from someone on another board who pointed me to the fusible link(s). I tested them all and one didn't register. Repaired that and BINGO! Fixed.
Thanks for your responses.
Misfit74 is offline
Old 11-09-2012, 07:29 PM
Thank you for posting what fixed your problem now when someone stumbles across this it will help them out and now I now another thing that will cause this problem
Jlo
02-03-2015 09:41 PM
Collector Car
01-05-2015 10:58 AM
fpete1992
12-11-2014 03:51 PM
siguy
11-27-2014 10:07 AM
squarehead
11-21-2014 08:02 PM
Quick Reply: Dash, Tail, Fog, and Interior Lights Not Working
