Aftermarket CD Deck with stock Bose Speaker/Amp system?
I have the stock 5 speaker Bose system and want to put in an aftermarket CD player (Pioneer). I have heard that an aftermarket CD player can cause distortion in lower volumes. I was wondering if anyone has any more info on this. I really want this stereo but I dont want any distortion Thanks
James - 1996 Cayenne Red Metallic Z28
Administrator/Webmaster/Member of the Camaro Z28 Owners Association
18x9.5 Chrome Z06 Wheels, RKSport SS Hood, LT4 HotCam Kit, AS&M Headers, BMR STB, Bilstein Shocks, Eibach ProKit Springs
Pics
AIM - CamaroHeed
"If you can't catch my attention, you aren't worth racing"
Pics
AIM - CamaroHeed
Bose HU's have line level outputs to an amp mounted on each individual Bose speaker...you can't just change HU's in a Bose system without a special adapter. Unfortunately, no one around here seems to know specifically what adapter is needed, and since I don't have a Bose system, I can't say either.
You might want to contact PAC at www.go2pac.com to see if they can help you. (incorrect statement edited out)
Good luck!
[This message has been edited by BandDirector Blk98ZM6 (edited July 10, 2002).]
[This message has been edited by BandDirector Blk98ZM6 (edited July 11, 2002).]
Good luck!
<font face="Verdana, Arial" size="2">Originally posted by BandDirector Blk98ZM6:
[This message has been edited by BandDirector Blk98ZM6 (edited July 10, 2002).]</font>
You do not have to have a special adaptor. The people that tell you that is either trying to get your money on something you don't need or they don't know any better. I'm an install at a car audio shop and we've put several aftermarket decks into cars with the bose system. One of those was mine. All you got to have is the standard GM wiring harness (Metra 70-1858). We sell it for $14.95. All you got to do is wire it up color to color and hook the remote turn on wire off the aftermarket deck to the solid blue wire on the wiring harness to turn the bose amps on. It works fine like that. The only problem with that is you get some background hiss and you have very limited volume control. Meaning that if your volume on your stereo goes to 80 and normally it will max out and distort around 70ish then if you got in with the bose system you will max out and begin to distort around 40ish. But the volume at 30 with the bose system will be like it would be normally at 65ish. I personally recommend replacing all the bose stuff with aftermarket equipment. But you can put a aftermarket deck in with the bose system without a "special" harness. You can't put aftermarket speakers in with the bose system cause the bose speakers are 1 ohm and most aftermarket speakers are 4 ohm which would be very week in the bose system.
95 Z28, A4, Green, T-Tops.
Flowmaster Exhaust, K&N CAI.
#3 Forever!!! God Bless You Dale!
Moderator at www.z28owners.net
[This message has been edited by Shawnster95Z28 (edited July 11, 2002).]
...you do NOT need the PAC OEM-1. The OEM-1 is ONLY for people who want to KEEP their stock HU and then add aftermarket amp/speakers.</font>
Since the OEM-1 has output level controls it should also compensate for the volume setting problem mentioned above. The reason for the problem is that the signal from the HU is too strong without the level controls to tone it down a bit. That's why you reach maximum loudness so soon on the volume setting.
<font face="Verdana, Arial" size="2">Originally posted by LS1 RULZ:
I don't believe this is true. The ADD-GM21 harness is meant to be used with the OEM-1 when it is used to add an HU to a BOSE system. The ADD-GM21C is used to add an aftermarket amp/speakers to the Monsoon system.
</font>
</font>
I'll be damned! I stand corrected. I just double checked PAC's website. It does appear the ROEM-1 is for people who want to replace the HU in a Bose system and the ROEM is part of the OEM-1 line of products. It appears that the AOEM-1 is for people who want to keep their Bose amplifiers as well as add an aftermarket amp and the ROEM-1 is for people who simply want change Bose HU's, but keep Bose amps. However, I am correct that the OEM-1 is NOT necessary to replace the HU in a Monsoon system.
Shawnster95Z28, it does sound sound like you don't NEED a harness just to make it work, but after your description of the hiss and volume control problems, it seems to me that the reason you would be replacing the Bose HU is for better sound, and if you're adding hiss and volume control problems, that defeats the purpose of replacing the HU. If the OEM-1 solves those 2 problems, then I would think that the OEM-1 adapter would be the way to go then if the purpose of replacing your HU is to improve the stereo system.
I don't own a Bose equipped F-Body, and never have, so I guess I just need to give up on giving out advice on which I know nothing about
I don't own a Bose equipped F-Body, and never have, so I guess I just need to give up on giving out advice on which I know nothing about </font>
<font face="Verdana, Arial" size="2">Originally posted by Shawnster95Z28:
...I strongly suggest is don't bother with mixing aftermarket and Bose stuff, and just do a "Bose-ectomy" and replace everything with aftermarket equipment and be done with it.
</font>
</font>
Just as an FYI, I have a nice Kenwood Z228 deck hooked up to an otherwise complete Bose system in a 1996 SS Camaro. While what has been said above about the volume is true, I don't have a hissing problem with mine. I only turn it up maybe a little over half way and it is VERY loud but even at low volume, I don't have the hiss. I, like the other guy, have done this several times and have never had a complaint (done it in 3 of my f-bodies and for several friends). IMO, it sounds better than the stock Bose head unit.
While I'll agree that replacing the entire setup is the way to go, if you're on a budget, just hooking up an aftermarket head unit with a $4 Wal-Mart GM wiring adapter harness does work.
Another thing to add is I have factory service manuals for the 94 and 96 F-Bodies. I don't see any speakers that are 1 ohm The speakers for the Firebird and Camaro systems are well above 1 ohm.
Brent Franker * Main Page
94 Vortech Z28 * 96 Z28 SS #1655
4th Gen Appearance Modification Guide
F-Body Install & Fix-It Guides
<font face="Verdana, Arial" size="2">Originally posted by Brent94Z:
</font>
</font>
The speakers with the Bose speakers are 1 ohm. The standard stock speakers with the standard stereo system is 4 ohm.
</font>
</font>
95 camaro z28 6 speed with a slippy cluth new slp pp, disk, cold air intake, air foil and skip shift elimanator in the mail
Re: Aftermarket CD Deck with stock Bose Speaker/Amp system?
I know you posted this years ago but I am having an issue where only the rear passenger speaker works after hooking up aftermarket deck with bose system in a 96. I tried to hook the blue antenna control wire from the deck and the blue/white power wire to the blue power wire on the gm harness and that did not work. any advice?
