1994 z28 convertable speaker issues
I was wondering if i could replace the factory door and rear speakers that are 5.5 inches with 6.5 inches aftermarket. i measured the speakers and they are 5.5, cone and the outer rubber piece. the door speakers are attached to a plastic housing while the rear ones bolt on the body. any suggestions would be appreciated. thanks
Re: 1994 z28 convertable speaker issues
I have replaced the rear and the driver side in my 95 camaro convertible. I bought 6.5 inch speakers and they were actually small for the holes. You could easily for 6 3/4 in the holes.
I have a 96 convertible I replaced all 4 speakers with 6 1/2 but it has been 10 years ago so my memory may be a little off. ... the screw holes didn't line up I could only get 2 of the holes to line up never had any problem with just having 2 screws in them watch out for the mounting depth on the doors you don't want them to hit the windows when you let them down
www.crutchfield.com
www.crutchfield.com
Get a shallow mount version for the rear to avoid any contact moving parts for the top lift assy.
If running an 5 channel amp and sub, set your crossovers for all 4 6.5" @ high pass 70-80hz (whatever your head unit-amp will allow)
Drop a bazooka dual 4 Ohm voice coil 10"-12" sub in the back crossed @ low pass 80hz and you'll have plenty of tunes with the top up or down.
94z28jbw
09-08-2002 03:22 PM
