"camaro" panel on back rattles!
ok, ive figured EXACTLY where the rattling comes from...
i have 2 12" JLW3s... hit hard as hell...well..getting to the point...
well the panal that says camaro on the back of the car(above bumper) is the ONLY thing that rattles in/on my car... when i get 2 people to hold it down, hard, its doesnt rattle at all, even when blairing!...well
im thinking i need to put a small foam or rag or something between it and the car, how can i take it out to get something behind it? looks like i need to take out the tail lights... is it hard to do that?!!?!?
THX
cory
- 1998 Black Camaro A4 -
3800 Series II V6
K&N Filter
AOL/AIM: Binkyboy88
This is my AIM buddy icon:
http://www.angelfire.com/nb/corycamaro
THX
cory
3800 Series II V6
K&N Filter
AOL/AIM: Binkyboy88
actually, it's the hatch lock not the panel that is rattling. I thought it was that also, but it was after I removed the panel and kept it off and turned my system up is where I tracked down the problem. Still haven't found a solution yet
1997 Camaro Z-28 SS #0728
Flowmaster, Hooker Header tips, BMR strut tower brace, lower control arm and relocation bracket, Optima Yellow Top battery, Granatelli lowering springs, KYB AGX shocks, Lakewood panhard rod, Bear bump steer, 17 x 9.5 Z06 rims
Audio/Video:
Head Unit ----- Pioneer AVX-P7000CD
Master Unit --- Pioneer AVM-P9000R
DVD Player ---- Pioneer XDV-P9
Front --- Focal Polykevlar 165K2 w/ TN-51 tweeters
Rear ---- Focal Polykevlar 165K2
Sub ----- Lightning Audio 10.2.4
Amp ----- Phoenix Gold XS6600
My SS homepage
CAR AUDIO PLANET
Georgia F-Body Association
Audio/Video:
My SS homepage
CAR AUDIO PLANET
Well, I would get some of that foam that you use to put in door ways to stop air leaks and it had a sticky side! I would place it around the seam where the hatch hits. It should asorbe the vibration Let me know how it turns out!
95 Camaro 3.4L M5,
-Flowmaster muffler 80 series with quad tips,
-White Racing Stripes
-LeBra front end cover,
-Interior purple neons
-2000 Trans Am rims
-Car audio
180 Watt Kenwood head unit
jbl's all around
2 10" Jensen 375 watt subs with a 250 watt amp (I know its cheap but I really don't want to kill any little old ladies)
http://members.glis.net/zomie
95 Camaro 3.4L M5,
-2000 Trans Am rims
-Car audio
jbl's all around
ok, it COULD be that but... why would it stop rattling when i pushed down on that panel???
im gonna try it with the hatch up tomorrow (to late now, wake up all the old people), i just dont think thats it, but ill try, thx for the input, ill say results tomorrow...
if it isnt that, still doesnt anyone know how to get that panel off so i can pull foam or something behind it??
thx cory
3800 Series II V6
K&N Filter
AOL/AIM: Binkyboy88
thx cory
3800 Series II V6
K&N Filter
AOL/AIM: Binkyboy88
I don't know if its different on the 98, my guess is its not. but you peel back your carpet along the inside wall of your trunk. there should be two black plastic wing nuts that hold each taillight on. then there are two 10mm nuts on each side of the car that hold onto the panel. thats the way it is on my 94. i'm in the process of putting dynamat on the inside of that panel. i put some original on it b/c the stereo store recommended it, but it only quieted the panel down a little bit. I'm going to go back and buy some extreme dynamat. goodluck. also the latch rattler. on each side of the hatch while its up, theres a little black nub/bumpstop, turn it out 1/2 turn at a time, it should tighten your latch up, but if you go too far your wing/fender lines will mess up. gl
Tyler Parsons
'90 FZR 600
'85 IROC-Z
'94 Camaro 3.4L
'78 Blazer 350
Tyler Parsons
'90 FZR 600
'85 IROC-Z
'94 Camaro 3.4L
'78 Blazer 350
This is what I did.. I took styrofoam pads and stuck them behind the panel.. I couldnt figure out how to get it off so I wedged them up there from the bottom. There is a small opening at the bottom if you look.. now I am rattle free
I had the same problem. The lock broke completely off so I removed it. That was some of the rattle problem. I just use the keyless plus I dont have to worry about the old screwdriver theft approach. The main problem is the rear cover as others have mentioned. a lot of soft foam. Youd have to drop the bumper to really pack the foam.
Black 00' SS
(3) Solobaric L7s
(3) Earthquake 200Ds
(3) Marine Batteries
(6) Farad Caps
(2) 15" Compression Drivers (Loud AZZ Highs)
(1) Broken Trunk Latch courtesy of the L7s
C.A.N.I.
Conastant And NeverEnding Improvement
Black 00' SS
(3) Solobaric L7s
(6) Farad Caps
C.A.N.I.
squarehead
11-21-2014 08:02 PM
