Autocross and Road Racing Technique There is more to life than a straight line
View Poll Results: WHICH DO YOU PREFER LOOKING AT
GEN 5 CAMARO
15.38%
PAMELA ANDERSON
84.62%
Voters: 13. You may not vote on this poll
Ultimate Bolt-On Project or Racers Wet Dream
Old 04-23-2010, 03:09 PM
DMS Motorsports's Avatar
Oops, wrong dream. This dream is to build a NASCAR style circle track car from a body in white and do it in an environmentally positive way. The dream is to go racing with E85, cats and be socially responsible AND beat the traditional style race cars that are HD polluters. On top of that, we do it on a reasonable budget with off the shelf parts so that this class of racing is available to most anyone who can turn a wrench along with a couple of buddies in his garage.
Green
Racing
Experimental
Engine
Narrative
Times change and so will racing. An All-Star group has been assembled by Robert Fisher and Circle Track magazine to build and track a 2010 Camaro using renewable fuels. It goes well beyond fuels and to the heart of what racing is all about -- cars on the track that are like the cars we drive on the street. If all goes well, they will put on track a car that captures the essence of NASCAR Back-in-the-Day with superior technology, superior performance that runs clean while using renewable fuels.
This is great stuff. Carburetors vs Fuel Injection, E85 vs Full Fossil Fuel, Real Cars on the Track vs Skins on a Chassis that has NOTHING to do with a Car in a Showroom... Why does Toyota spend money to run a Camry in NASCAR when they sell front wheel drive sedans? Ooops, that is a different article.
We could not be more excited to be a partner in this project. Pedders will supply the suspension and it will be as advanced as the engine technology in Project G.R.E.E.N.
164086 Camaro Sports Ryder Supercar 52mm with Remote Canister
CAMAROSOLUTIONC 27mm F & 32mm R bars & 4 links
EP1167HD Zeta HD Differential Mounts
EP1201HD Camaro HD Rear Sub Frame Repl
EP2112 Zeta Steering Rack/Pinion Mnt
EP6577 Camaro Front Radius Rod Bush
EP7264 Zeta Rear Lower Control Arm In
EP7322 Camaro Rear Upper Control Arm
EP7323 Zeta Rear Trailing ArmToe Link
PDUSACAM2800 Camaro Complete Brake Hose Kit
PDUSACAMFULL Camaro Full Alignment Kit
You'll be able to follow this project in print or online is Circle Track magazine.
Dyno Test #1
I feel the need for moonshine, make that E85
thanks
mike
dms
DMS Motorsports is offline
Old 04-24-2010, 03:43 AM
West South Central Moderator
AdioSS's Avatar
that's pretty cool!
AdioSS is offline
Old 04-24-2010, 04:17 AM
dangalla's Avatar
there was no gen 4 option
so i had to pick Pamela Anderson
dangalla is offline
Old 04-24-2010, 08:16 AM
slowride94z's Avatar
so far PA is kicking ***
slowride94z is offline
Old 04-24-2010, 11:35 AM
Justice Pete's Avatar
Is this a Camaro forum or the PA FanClub?
Justice Pete is offline
Old 04-24-2010, 11:42 AM
I think we can use these polls to find out who is married or not! LOL
mike
dms
Old 04-27-2010, 05:42 PM
Project G.R.E.E.N. Dyno Test #1 - Engine
Initial Results For Our First Engine Dyno Session Open Up Some Distinct Possibilities For Future "Green" Racing
From the March, 2010 issue of Circle Track
By Jim McFarland
Photography by Rob Fisher
Reprinted here with the permission of Circle Track magazine.
This project is clearly getting some traction. While initial reader responses have largely been in support of CT's "green racing initiative," there has not been sufficient, hard data to support the project's viability . . . until now. In the following paragraphs, you'll have an opportunity to review the unwashed results for our first engine dynamometer session at Mast Motorsports. Fortunately, several of the players from whom you heard comments a month or so ago were present for and participated in the tests. You'll recall previous observations from Rob Fisher (CT's Editor), Forrest Jehlik (key project engineer from Argonne Laboratories), Dave Kalen (Account Executive and motorsports enthusiast from Semtech, the PEMS company), and Horace Mast (mechanical engineer and owner of Mast Motorsports). A follow up story with their comments relative to this test begins on page 40 immediately after this feature. You will likely be interested in what they reveal.
In order to help you derive the most benefit from the dyno results, we've chosen to focus our discussion on the graphical representations the data provides. The computer skills of Forrest Jehlik produced the graphs shown. Our belief is that by looking at the "visuals" and correlating them with the practical and theoretical perspectives they reveal, you'll come away with the majority of your questions answered, for now. At least that is our intent. We'll also tack on a few concluding remarks at the end of the story as we head into the project's next phases.
Fuels Comparison Although 93-octane gasoline was included to compare it with 100-octane racing gasoline (actually blended with 10 percent ethanol to raise the octane rating) and E85, a lack of performance resulted in its removal for the continued analyses. As a result, the 100-octane "Street Blaze" gasoline and E85 (both from VP Fuels) became the fuels used for subsequent tests.
As you will note, data from the "fuels comparison" tests show a torque and power degradation from about 4,000 rpm to peak rpm at 6,750 where the output from all three fuels converged to approximately the same value. Largely attributable to the engine's overall diminishing volumetric efficiency relative to net airflow at higher rpm, other factors played into this convergence. However, from 4,000 rpm to around 6,250, E85 tested marginally better than the 100-octane Street Blaze. (Note: At this point, it's important to know all tests were conducted using the same ECU calibration. For multiple reasons, parts-specific spark and fuel maps were not sought to optimization. Future tests will address that issue.) The data shown indicates only slight differences (w.o.t. throttle, full load) between the torque output comparing 100-octane racing gasoline to E85. As a result, power output differences you will see comparing data from various parts combinations (EFI, carburetion, catalysts, and so on) will be true to the differences such parts represent, not owing to variations in fuel performance.
Carburetion vs. EFI At the moment, there seems to have been two areas of particular interest among racers and engine builders regarding a shift away from the conventional use of carburetors and racing gasoline. One pertains to how much power might be lost, switching to EFI, and the other the extent to which catalytic converters would reduce on-track performance.
If you subscribe to the notion that torque is a major factor in race car acceleration, you may find the torque curves displayed in the attending graph of interest. In particular, aside from the approximate 7 percent gain in torque (at the rpm of greatest torque difference or roughly 4,500 rpm), note the general broadening and flattening of the overall torque curve produced by the EFI and 100-octane package. Part of this can be traced to improved fuel atomization (a topic discussed in previous "Enginology" columns) and in part to a basic intake manifold design that favors low- and mid-range torque.
This latter condition can also have influence on peak power (compared to a single-plane manifold with inlet runners shorter than the EFI manifold), and you can see the effect of this factor at peak rpm. However, there is evidence of where in the engine speed range an improvement in torque can build a case for better on-track performance potential using the EFI system. Also note that neither of these tests was conducted with catalytic converters in place. More on this a bit later in the story.
Catalyst vs. No Catalyst Interesting stuff here. If you'll refer to the previous graph (Carburetor vs. Fuel Injection), you'll note that peak torque for the EFI and 100-octane Street Blaze gasoline was a corrected 496 lb-ft. Compare this with the configuration (catalyst vs. no catalyst) of EFI, 100-octane street blend and the 100 cpi (cells per inch) catalysts and you'll see only 5 lb-ft of torque were lost at peak torque. Plus the previously broadened and flattened torque curve (from around 3,250 to 5,500 rpm) was retained as a function of the EFI manifold design.
So for those who might believe the addition of catalysts would have a materially negative effect on overall torque output, here's some data to consider. The fact peak horsepower and torque output (with and without the catalysts) was virtually the same again points to other factors, including maximum volumetric efficiency obtainable (at higher rpm) with this parts package. Once again as a reminder, at this stage in the project, no attempt was made to optimize either functional integration of parts or best ECU calibration.
Carbureted baseline with 100 street blaze gasoline without catalysts vs. EFI with E85 and 100 CPI catalytic converters You may want to spend a little time studying these results. The baseline data was recorded using a carburetor, 100-octane Street Blaze racing gasoline, and no catalytic converters. Note peak horsepower was a corrected 552 hp, compared to a corrected 539 peak horsepower for the EFI, E85, 100 cpi catalytic converters package. Admittedly, given the current parts configuration, peak power decreased 13 hp. But before you condemn this outcome, pay attention to the way the EFI parts combination affected corrected torque from about 3,500 to 5,500 rpm (plus-22 lb-ft). Given how a particular circle track car might be geared and the track layout, this span of rpm could fall within a very desirable range of on-track engine speed.
In addition, if you will refer to the Carburetor vs. EFI data graph, you'll discover peak torque (EFI, E85, and no catalysts) produced a corrected peak torque value of 498 lb-ft. Compare this value with peak torque (carbureted baseline with 100 street blend gasoline without catalysts vs. EFI with E85 and 100 cpi catalysts) for the EFI, E85, and catalysts package at 499. Maybe this comparison sheds light on some conventional thinking that suggests catalysts will materially decrease power.
Catalyst Substrate Density Comparison While these data get into the minutia of how pumping losses can affect power and the effects of catalyst density on such losses, you can see that increasing substrate density by a factor of three (from 100 to 300 cpi) still allows the higher density, EFI, E85 catalytic converters combination to produce superior torque when compared to the carbureted, 100-octane Street Blaze, no catalysts package (by a higher peak torque value of 12 lb-ft).
Old 05-02-2010, 11:13 AM
Check out the engine dyno run on U Tube:
mike
dms
Old 05-03-2010, 01:37 PM
I did.
Mikes 1994 z28
10-10-2015 07:55 AM
NewsBot
09-14-2015 09:20 AM
meissen
08-11-2015 06:05 AM
Rittmeister
08-07-2015 01:13 AM
Boss002
07-09-2015 03:33 PM
Quick Reply: Ultimate Bolt-On Project or Racers Wet Dream
