Autocross and Road Racing Technique There is more to life than a straight line
Spring help
Old 08-29-2004, 10:04 PM
BloodshotLt1's Avatar
Spring help
I have recently purchased a 95 T/A that has been lowered with Eibach pro springs, has Bilstien shocks. I am looking to change these springs as they are too low and ever time I hit a bump they bottom out on the drivers side. I autocross this so this needs to be fixed. Any ideas what kind of springs would be good.
BloodshotLt1 is offline
Old 08-30-2004, 08:04 PM
Jabberwocky's Avatar
Re: Spring help
Eibach drop the car only about an inch. I run my car in ESP and it's dropped more than an inch and I'm fine. I think something else my be the culprit here. Are the front shocks still dampening properly?
Jabberwocky is offline
Old 08-30-2004, 10:49 PM
Re: Spring help
They seem to be working fine, I really dont know how to tell if a shock is bad other than fluid leaking. If I knew how to post a picture on thisforum I would put a pic of car up so all could see , it is pretty damn low.
I have already installed LG Motorsports LCA's and a BMR double adjustable panhard rod, it has LG world challenge wheels 17x10 and BFG GForce rubber. but nothing seems to keep the tires from scrubbing the wheel wells when hitting bumps or dips.
Old 08-31-2004, 01:50 PM
Re: Spring help
When you hit a bump or dip, does the car oscillate more than once? Kinda like the way jello oscillates when you hit it. If you are mathematically inclined, think of the dampening harmonic function.
Also. Do your wheels shake cornering? I suck at diagnosing problem, usually I'll ask someone to ridealong to find out what's wrong. But there are alot of ppl with your setup and they don't seem to have the scraping problems you describe.
Old 08-31-2004, 03:55 PM
Re: Spring help
I have not noticed any problems when cornering.
If it is a ripple or dip in the road sometimes it will scrape a couple of times, what it is is the outside edge of the tires are scraping on the inside of the fender wells.
Old 09-02-2004, 03:57 PM
TankII's Avatar
Re: Spring help
Has anything else been done to the car? Are the swaybars still stock? Rims/tires? You shouldn't rub unless something else has been done (larger or offset rims/tires), or your struts are set too soft for the springs.
I have a set of Eiback Pros on my SHO. With Blizzacks, I rub over large highway dips in the road (car actually gets light on one in particular) but with the set of G-Force KDW it doesn't. It's the height of the tire that makes the difference for me. My Koni settings didn't make any difference.
I am running stock size/offset rims on both sets of tires.
I just stiffened the rear swaybar up by using a much better design of stock dimension end-link, and the car handles flatter. I'll report back in the winter if the snow tires still rub!
TankII.
TankII is offline
Old 09-02-2004, 05:00 PM
Re: Spring help
I have 17x10's BFG KDW tires, LG motorsports LCA's, and sway bars front and back, and BMR double adjustable PH rod.
Old 09-02-2004, 06:46 PM
Re: Spring help
You definately need to take a hammer an hammer in part of the rear tirewell where it rubs. Still don't know why you are scraping though. Measure your rideheight. From ground to should be 26-26.5 in the front I think.
Old 09-02-2004, 09:00 PM
Re: Spring help
I dont understand, from ground to what. is that 26-26.5 mm,cm,inches what?
Old 09-03-2004, 12:33 AM
Re: Spring help
It's inches.
Old 09-05-2004, 01:34 AM
wbna0149's Avatar
Re: Spring help
Are you sure the springs are the pro series and not the Sport line series? It sounds like the vehicle is equipped with sport lines from your description.
wbna0149 is offline
95z28man7
N2O Tech
08-16-2015 10:58 AM
9t4lt4z28
Parts Wanted
07-19-2015 06:16 PM
Z28amustangklr
07-18-2015 11:05 AM
Catmaigne
07-14-2015 05:17 PM
Quick Reply: Spring help
