Lower Control Arms LCA's Install
I just installed some LCAs on my car.
First off, These are WAYYYY under rated. After the bolt ons this should be suggested as the next step. They stiffened up the rear end so much around corners its redicilous. Also i had HUGE traction problems before them, i would just sit still roastin the tires, but now it Launches straight, and it gets alot better traction. On the install side, it was easy but only after i learned that it lines up better on the ground and when you jack up the car slowly if the holes arent lined up it drops in like butter. Little tips that could have helped the first side install. The after market LCAs dont look like much but they are soooooo much stronger then the stock pieces. Just wanted to share my experience with everyone. i thought just power adders would lower the 1/4 time, and let me beat more cars but im now a firm believer that suspension is underrated.
