Alignment specs for stock 4th gen?
My car is a mostly stock 4th gen (sway bars, shocks, etc.) and is on stock springs. What's a good alignment to start with for autocross? Wear on tires and driveability isn't much of a factor since this is a weekend car.
Re: Alignment specs for stock 4th gen?
Along that line, shocks are a MUST. The car is very competitive in stock class (where it's cheapest to run too). You simply need the alignment, some proper shocks and more front swaybar (R-tires too). That's it.
Re: Re: Alignment specs for stock 4th gen?
Originally posted by 01 FS Z28
Maximize you negative camber (in an LT1 that'd be about -.75 or so). Max the positive caster (likely in the +4-5 degree range). Run between zero and 1/8" total toe-out. Works well enough to win me the '02 ProSolo title in my 2001 Z28. Also, the car that finished 3rd in the series was a '95 I setup as well. My car also finished 2nd @ Solo2 Nat's with a friend driving (I was in ESP).
I don't autox, just street driven.
Hey. I know this is an old post. Sorry i am new to the fourms. But ibhave spent a lot of time lately reading up on alignment and pros and cons to it all. At the moment i have a 94 Z28. Lowered 1.8 inches with quite a bit done but im wanting the best handling i can get from it. I have got it pretty well figured out now after reading through info and your reply to the question asked. My final question os concerning Toe. I know lowered i can ge approx. 1° camber and likely 5° caster approx. But the car being lowered should i then run any more then the 1/8 inch toe out to compensate for the car being lowered and if so do you have any suggestions.
Again sorry i know its an old post. But thank you for any help you can be!!!
Joe.
oldschool
02-09-2016 09:21 PM
Brandon Wittmer
12-20-2014 09:51 PM
