Pacific Alaska, California, Hawaii, Oregon and Washington
Drag Radials
Old Mar 27, 2003 | 02:16 AM
ollie-99's Avatar
Drag Radials
Anyone have any for sale?
or some old salad shooter rims for sale?
im gunna use em @ the track instead of ripping apart my new tires.
Also will i blow up my rear end using them?
-Oliver
Old Mar 27, 2003 | 03:59 AM
LuCiFeR97Z28's Avatar
Re: Drag Radials
As has been stated a billion times before:
MODS + 10 Bolt = Living On Borrowed Time
It's not a matter of IF, its a matter of WHEN. People will tell you that you're not making enough power to blow the stock rear, but it can and does happen.
A.
Old Mar 27, 2003 | 10:22 AM
CoryM's Avatar
Hey now, real 10 bolts are plenty tough . Not these weak *** 7.5" in 4th gens though. I cant figure that one out. Lets make a car with more power,better traction and a weaker rear end .
Old Mar 27, 2003 | 12:09 PM
JD30thZ28's Avatar
Aly hit it right on the head You can run them you may or may not break it, but with DR's the chances are lower than slicks but of course higher than street tires....because on the most part you will spin the DR's thus in turn not causing too much shock on the driveline. I have been running DR's on my stock rear with Nitrous launches but then again i can load my driveline up Although my DR's do still spin a bit when i launch.
Old Mar 27, 2003 | 10:20 PM
Camaro ChriSS's Avatar
Yeah man. But that 10-bolt of your's is a whole different beast... That's the way they should all be built.
RUENUF
Mar 13, 2016 03:37 PM
HAWG
Sep 25, 2015 11:41 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
