4000 stall in a daily driven car?
Old Mar 25, 2003 | 10:08 PM
z2894convertible's Avatar
Question 4000 stall in a daily driven car?
How would this be different than a stock stall on a daily driven car? I have never been in a car with an aftermarket stall. I am just curious as to how they are different on the street and at the track.
Old Mar 25, 2003 | 10:17 PM
thelategreatz28's Avatar
TTT, I wanna know too
larson_lars64's Avatar
well if it was me, i wouldn't do it, at least not 4000. Maybe like 2500 or 3000 at the most. Basically a 4000 stall means that the car won't start pulling hard until 4000 rpm's, and that's alot of rpm's to get up to for the street as a daily driver.
Old Mar 25, 2003 | 10:45 PM
Smokn '94 Z's Avatar
Re: 4000 stall in a daily driven car?
My vig 3200 stall is pretty good on the street. I don't see anything wrong with it. But if my car were a daily driver I wouldn't go more than 3200. I am now gonna run a 3600 stall. We'll see..
Old Mar 25, 2003 | 10:50 PM
Wild1's Avatar
Rush hour traffic might be an issue too... not sure how a 4000 stall works with stop and go.
Old Mar 25, 2003 | 10:51 PM
Don 97 SS's Avatar
Put a 4,000 stall on a daily driver and you will be crying.
Old Mar 25, 2003 | 11:06 PM
neil350's Avatar
4K, getting little agressive there.
Old Mar 26, 2003 | 06:33 AM
Derrick Redd's Avatar
I'm running a 3,600 stall. It's not bad at all. Should be even more drivable with the added torque of the 383.
Old Mar 26, 2003 | 06:44 AM
Smoke T/A's Avatar
I have a 4200 stall in my 98Z drive it most every day and it is fine. I would just make sure you have a good tranny cooler if you are going to drive in stop and go traffic every day.
Old Mar 26, 2003 | 07:17 AM
BES-383's Avatar
Why is it every one has a comment on something they know nothing about.
larson_lars64
Junior Member
__________________
93 z28, completely stock, purple pearl metalic, 44k, 3.23 gears, bose
pics of my drag car http://community.webshots.com/user/larson_lars64
Completely stock. what advice can you
give?
Wild1
Member
Rush hour traffic might be an issue too... not sure how a 4000 stall works -with stop and go.
If you do not know how a 4000 stall works why to you reply?
Don 97 SS
Prominent Member
__________________
HurstM6/CNC heads/11:1cr/SS 2”valves/Crower SS 1.6rr/HD rods/Crane2033 Cam/Crane dual springs/HPP+w/module & 160stat/52mm TB/SLPafpr/1LE bellows airfoil/G2 breather/aluminum valve covers/Magnecor 8.5mm wires/MSD Digital6+/SLP 1.75”ss coated hdrs/ss Y-pipe w/2 Random cats/LPE 3.5”shaft/pulleys/LT4km/ K&N/Torsen/poly stuff/ SLP pp, flywheel w/McLeod disc/GM3.73 gears/LS1 brakes/ HotchkisLCA&STB/349rwHP/349rwTQ-corrected
You drive a M6. You ever drive an auto with a high stall?
I dont get it how so many people have an oppinion about something that they don't have a clue about.?
Old Mar 26, 2003 | 07:27 AM
I have never rode in a car with an aftermarket stall before. I am trying to get an idea of how it will be different than my stock stall. Such as will I be reving higher rpms when I take off normally, will I have to give it more gas to get the car moveing, etc...
Jeff, you will be needing to change your sig to a turbo 400 soon
Old Mar 26, 2003 | 07:48 AM
Don 97 SS's Avatar
BS-383, I have an opinion and it happens to be different than yours. I'm not clueless. I have owned vehicles with high stalls, that why I have this opinion. I'm 51 y.o. and have been in this hobby for a number of years. One should have more information regarding use of the vehicle, the engine modifications, etc prior to properly recommending a particluar converter stall speed.
I don't doubt that you are happy with your 4000 stall...but that's your opinion.
I have a friend that builds engines for a living and races most weekends in his blown alcohol fuelie SBC roadster (5.0x @ 140mph in eight). I help by crewing sometimes. He loves his 4000 stall also.
Old Mar 26, 2003 | 08:17 AM
Lightbulb
You shouldn't have dignified his post with a comment. I found if you ignore rude, disrespectfull people they tend to go away...
Old Mar 26, 2003 | 11:23 AM
Wild1's Avatar
I guess you get a lot of rush hour traffic in Maysville (whatever), Ky.
Old Mar 26, 2003 | 06:38 PM
[i] One should have more information regarding use of the vehicle, the engine modifications, etc prior to properly recommending a particluar converter stall speed. [/B]
The car is driven pretty often. I have a hotcam kit, LT's, CAI, Borla, crank pulley, stage 2 ported heads, 3.73's, Walbro, air foil, 1LE elbow, !EGR, !AIR, !cat, TA girdle, and there may be a couple of other small things that I am forgetting. NX wet kit waiting to be put on
