Sitting High
Old Mar 25, 2003 | 08:49 PM
LT1PWRD's Avatar
Sitting High
Last week I installed SLP Springs, Hotchkis Shocks, Front sway bar and End links front and rear.
According to SLP, It would only drop about half an inch but my car is sitting higher up front then the LS1 cars. The rear seams OK.
I double checked the installation and the springs are sitting where they should be and even loosened the sway bar brackets and tighened them while the car was on level ground.
I did also replaced the front shock mounting brackets and they were the same as what came out so nothing is different other than they're newer.
What else will make it sit higher like that, It's been a week so everything should have settled by now. It's real anoying to see the front so high like that.
69z-28
Jan 29, 2016 10:46 PM
blac94Z
19
May 13, 2015 04:50 PM
pimpss96
Feb 12, 2015 01:28 PM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
