Head removal questions
Old Mar 25, 2003 | 08:48 PM
lrm95transam's Avatar
Lightbulb Head removal questions
I have a 95 LT1...im takin off the heads...ALL the headbolts are out....but on the pass side there is that 1 damn bracket, i think the power steering pump is on? its got a pulley on it and is bolted directly to the damn head....how does that come off? i saw a few bolts...do i need a pulley puller? what do i need? any easy tricks to gettin the biotch off?
Old Mar 25, 2003 | 08:58 PM
WJH'sFormula's Avatar
The power steering pump needs to be unbolted to get to the last bracket bolt. I forget the size, but all that needs to be done is rotate the pully around to access the ps pump bolts.
With the PS pump unbolted, you can move it out of the way enough to get to the last accessory bracket bolt.
viperkiller's Avatar
its been a while but i think i remember some holes in the pully that you can get to the bolts that hold the pump to the bracket 2 or 3 probably 10mm head
Old Mar 25, 2003 | 09:06 PM
i will have to check that...after those 3 bolts come out...head should come off?
oldschool
Feb 9, 2016 09:21 PM
LT14LIFE
Feb 9, 2015 09:35 PM
cmdeshon
Dec 27, 2014 10:06 AM
pologreen97z
Dec 2, 2014 10:42 AM
