South Atlantic Delaware, Florida, Georgia, Maryland, North Carolina, South Carolina, Virginia, and West Virginia
Turn signals
Old Mar 25, 2003 | 06:11 AM
gol10dr's Avatar
Angry Turn signals
My driver side turn signal won't work. It lights up but doesn't flash. I've replaced both front and rear turn lights. I checked the ground wire from both lights. The passenger side works perfectly fine. Any ideas where or what I should check now.
Old Mar 25, 2003 | 10:01 AM
MustangEater82's Avatar
IT hink there is some sort of turn signal relay that commonly goes out, make a post over at www.firebirdv6.com...
oddly enough my car I have only replaced one brake light(did them both to make the the same brightness, and one headlight, girlfrind knew it botherd me one was brighter so she bought me another one.
*knock on wood*
Old Mar 25, 2003 | 11:44 AM
darkoverlift's Avatar
Sounds like a POS car.... IMO I would sell it and get that LT you want...
Old Mar 25, 2003 | 11:57 AM
by the way...
so far the talk is my 1st, 3rd, 4th and 5th syncrhos are bad, at least what the guy thinks form test driving he hasn't pulled the tranny yet. So far everything looks warranty covered.
Old Mar 25, 2003 | 12:00 PM
Great... It will be nice to see you back out there smokin his 3.8 like it was easy to do...
Old Mar 25, 2003 | 03:43 PM
2002Z28SSConv's Avatar
There is a turn signal relay that is usually under the dash somewhere. It's what you hear clicking when the lights flash.
Old Mar 26, 2003 | 11:05 PM
Whistler's Avatar
The socket that the bulb goes in can be bad too. This is common.
Old Mar 26, 2003 | 11:45 PM
Seriosy awhile back there was an entire thread about this at www.firebirdv6.com
Old Mar 27, 2003 | 01:26 AM
Jsut skimming I found this thread...
http://www.camarov6.com/cgi-bin/ulti...c&f=1&t=004349
Old Mar 27, 2003 | 07:30 AM
anasazi's Avatar
turn signals? huh? no one around here uses those, don't worry about it
stangspank
Nov 13, 2015 01:02 PM
vinnyxgunz
Aug 28, 2002 09:41 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
CMJ917-95CMO
Jun 19, 2002 09:10 PM
