need help with performance parts??/
Old Mar 24, 2003 | 09:58 PM
qwick_trip's Avatar
ok i got a 95 z m6, these are the performance parts that i have on the car right now. catback exhaust, gutted cat, mac headers, 1.6 rr, double valve springs, hardend pushrods, lt4km, 150 dry shot, msd 6a ignition, msd coil, taylor plug wires, irridium plugs, 52mm holley tb, tb bypass, front sway bar removed, no sparetire and jack, egr blocked, air pump gone, fan relay, k&n cai, 3.5 steel driveshaft, moser 12bolt rearend w/3:73 gears, qa1 front and rear suspension, mickey tompson et streets, 5pt rollbar. i think thats it. what i want to know what else is there that i can do to make it go faster? nothing thats a long process like porting heads, intake, or new cam. just something that i could do in a short time. the only things i could think of is under drive pulleys and different mass air flow sensor!!
Old Mar 24, 2003 | 10:09 PM
LimitedEd1LE's Avatar
You could get a high flow cat for some better exhaust flow or just gut the cat. You could get some SFC's for better traction and a torque arm. You basically have all the basic bolt on's, so the only thing that would make a big difference would be to put a cam in.
Old Mar 25, 2003 | 08:01 AM
qwick_trip's Avatar
i know i would forget something! i got a cat back exhaust and gutted cat.!!!
Old Mar 25, 2003 | 08:09 AM
teke184's Avatar
how bouts an electric waterpump?
and long tubes instead of those macs...maybe a nice free flowing 3" true duals setup...
what kind of tuning do you have? stock or custom? look into madwolf or www.pcmforless.com
Old Mar 25, 2003 | 10:11 AM
I would say since you have a lot done and don't want to do a cam or heads, you should start to get some traction and suspension. You should invest in some LCA's, SFC's, relocation brackets, and maybe a panhard. BMR makes great suspension products.
Old Mar 25, 2003 | 10:14 AM
94T56T-TOPDREAM's Avatar
you did say gutted cat and cat back to begin with
Old Mar 25, 2003 | 12:08 PM
qwick_trip's Avatar
i went back and edited it. keep the ideas coming please???
i got the rollbar that stifended everything up no need for sub frame conectores. do lower control arms help alot??????
Old Mar 25, 2003 | 12:10 PM
teke184's Avatar
lca's made a dramatic improvement on wheel hop on my car... granted i was just spinning the crappy tires, but they spun smooth not jumpy from wheel hop.
i'd look into those and some relocation brackets to get some better traction, and also the torque arm that was mentioned...or at least install a polygraphit ta mount...
oldschool
Feb 9, 2016 09:21 PM
Doug Harden
29
Jul 30, 2003 07:05 AM
luvmyz28
Sep 15, 2002 04:36 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
