reading obd1
Old Mar 24, 2003 | 02:13 AM
Mellowdork's Avatar
reading obd1
On a 93 you guys can just jump two pins and then count the flashs right? What pins do you jump? And just wanting to make sher, the codes on the obd1 are more less the same on the obd2 right? Any help would be great. My friend's 93 through a code and ive never pulled a code off a 93 before. Im just use to useing my scan tool on my 96.
freddy
Old Mar 24, 2003 | 02:28 AM
stockLT1's Avatar
OBD1 and OBD2 are totally different as far as reading codes, OBD2 can't even be jumped.
I beleive it is the A and B terminal you jump to read the code, look in your manual or a chilton's to be sure though. If I remember right, it will be the two top right terminals on the DLC.
All you have to do is count the number of flashes, then you'll have your first digit, there will be a pause then it will flash again, that will be your second digit. It will only be a 2 digit code with OBD1.
Hope this helps, If not, feel free to e-mail me!
Old Mar 24, 2003 | 02:38 AM
Mellowdork's Avatar
Thanks man that helps alot. Yeah my chiltons dont talk about abd1 so im just winging it. So the codes are different too? Reason why i ask is because i have my book on the code translations for obd2. My friend is going to need a different book?
Old Mar 24, 2003 | 02:52 AM
stockLT1's Avatar
OBD2 is a 5 digit code, where OBD1 is a 2 digit code....like a 23 or 14 or somthing
OBD2 will have letters and numbers like a PO265 or somthing
Old Mar 24, 2003 | 07:38 AM
Pull 1993 codes
Old Mar 25, 2003 | 01:50 AM
Mellowdork's Avatar
ohhhh. thats right huh. umm. shoebox i cant get that link to work.
Old Mar 25, 2003 | 07:38 AM
Try now. My fault, sorry.
Old Mar 25, 2003 | 12:05 PM
stockLT1's Avatar
Sweet! I thought that was how to do it.
mightymouse383
Jul 20, 2016 07:34 AM
ad356
Apr 22, 2015 08:35 PM
greenzee28
Mar 26, 2015 09:13 AM
z28projects4ever
9
Jul 16, 2002 07:48 PM
