Intake valve closing point of LT4 hotcam
Old Mar 23, 2003 | 10:02 PM
LTOne4Fun's Avatar
How many degres ABDC is it?
Old Mar 23, 2003 | 10:46 PM
turbo_Z's Avatar
i dont think anyone knows because you cant find the advertised duration anywhere.... i have even looked on GM parts direct where they have listed every single cam you can get from GM.
Old Mar 24, 2003 | 12:08 AM
Robbie Pendergrass's Avatar
The best I can do-
Duration @ .006" - 272* I, 281* E
Hope this helps.
Old Mar 24, 2003 | 12:42 AM
turbo_Z's Avatar
well i got 68 degrees ABDC and about 52.5 degrees overlap.
Old Dec 10, 2005 | 12:42 PM
Fbody1's Avatar
Question Re: Intake valve closing point of LT4 hotcam
does anyone know for sure what #s are right for this ?
Old Dec 10, 2005 | 01:57 PM
Fbody1's Avatar
Talking Re: Intake valve closing point of LT4 hotcam
i found adv . duration of 279/287 but could not find what the intake valve closing . is 68* right? , tring to get my dcr w/11.6 sc.
Old Dec 10, 2005 | 07:16 PM
Fbody1's Avatar
does anyone know?
Old Dec 10, 2005 | 09:29 PM
1racerdude's Avatar
LT4 hot cam has a 272/281 advertised on a 112+3.
Intake closing is 65*
FB1=== give me your engine spects deck height,gasket thickness,piston depth,CC of valve reliefs,combustion chamber volumn,ect. and I will figure it for ya.
Old Dec 11, 2005 | 10:23 AM
Fbody1's Avatar
Deck Height=9.018 (Had .007 decked)
Gasket= 0.039
Piston= -5cc
Compression height piston= 1.560
Combustion Chamber cc= 52
Will be a 0.040 over bore
5.7 Rods, 3.48 Crank
Thank You
Old Dec 11, 2005 | 05:14 PM
1racerdude's Avatar
Gasket= 0.039
Piston= -5cc
Thank You
With a .039 gasket ya got 11.62 static and 9.23 DCR. If it was mine I wouldn't be affraid to run it that high WITH a good dyno tune.
With a .049 gasket(stock) ya got 11.29 static and 8.98 DCR. Thats more in line with the thinking for MAX with pump gas.
pimpss96
Feb 12, 2015 01:28 PM
MadMav
Feb 6, 2015 11:02 PM
ModdedNerd
Jan 29, 2015 07:23 PM
WildRidez
Jan 16, 2015 03:10 PM
