do all camaros come with aluminum driveshafts?
Old Mar 23, 2003 | 07:03 PM
whataretheodds's Avatar
do all 1998 thru 2002 come with aluminum driveshafts?
Old Mar 23, 2003 | 07:11 PM
southern94's Avatar
i always thought they did
but when i bought mine someone told me to check cause not all do
Mine has it so i am not sure.
Old Mar 23, 2003 | 07:13 PM
Mikael's Avatar
I think the only ones that don't are the 2.73 auto's
Old Mar 23, 2003 | 07:30 PM
Capn Pete's Avatar
Arrow
That could be true. My car has 2.73's/auto/steel driveshaft.
Old Mar 23, 2003 | 07:45 PM
chuck's Avatar
Yes, all 6-speeds and 3.23 geared autos have the aluminum shaft. The 2.73 cars get "the shaft".
Old Mar 23, 2003 | 07:50 PM
SFB767's Avatar
Speaking of the aluminum driveshaft, here's an interesting tidbit I learned about it not too long ago.
My car recently developed a "tink" when I shift in reverse and sometimes when I take off from a stop. I brought it to my local transmission shop and here's what the guy told me.
When GM makes these aluminum driveshafts for the F-Bodies, there is sometimes some metal shavings that get caught inside the driveshaft during welding and when it's sealed with Teflon, etc. etc., which causes the "tink". This guy is like Dr. Transmission, so I take his word for it. I was baffled to say the least when I learned what make that "tink".
Old Mar 24, 2003 | 12:19 AM
Ghost SS's Avatar
Not all F-bodies come with Aluminum DS's. All SS's come with it, and all Firehawks do. If you did not get the tire upgrade from the factory, which also gives you the speed limiter upgrade, then you will have a steel DS. I believe the lower speed limiter is at 115mph and if you got the better tires it takes it up to 158mph.
Old Mar 24, 2003 | 12:22 AM
stik6shift98's Avatar
i think its 118mph.......all i know is i have an aluminim driveshaft
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Noenav
Mar 1, 2019 07:38 AM
HectorM52
Jul 30, 2017 11:46 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
