Buying gears need help
Old Mar 23, 2003 | 04:45 PM
Joshua Hall's Avatar
I'm not sure what i need, i look at places like thunderracing and they have 2 different things for each set like motive 3.73 ring and pinion which is under 200 and they have the same thing with the master install kit for over 250 i think.... Do i need the install kit or is the ring and pinion what i need?
Old Mar 23, 2003 | 06:18 PM
insomniac 92z28's Avatar
You will need the kit. I would recommend GM superior gears for running quiet.
Old Mar 23, 2003 | 09:46 PM
What is the reason that i need the install kit????
Old Mar 23, 2003 | 10:40 PM
The install kit will contain a crush sleeve for your pinion, shims, bearings, gaskets, and new bolts for your ring gear.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
ddr698
Jan 9, 2015 10:05 AM
NewsBot
Jan 8, 2015 11:29 PM
cmdeshon
Dec 27, 2014 10:06 AM
