Cam recommendation from Comp Cams
Old Mar 22, 2003 | 06:28 PM
slammed98gmc's Avatar
I filled out the cam form on comps website and this is what they recommended for my 11.9:1 383 .Heads by loyd elliot with 2.02/1.60 valves,flow numbers here
SPEC CARD
PART #: 07-000-8
ENGINE: LT1/LT4
GRINDING INSTRUCTIONS 1
"" "" 2
GRIND #: LT1 3317 /3318 HR112.0
SPC INST 1:
SPC INST 2:
J. DIAM: STD INT EXH
VALVE ADJUSTMENT
GROSS VALVE LIFT .576 .600
DURATION @ .006
TAPPET LIFT 293 300
VALVE TIMING OPEN CLOSE
@ .050 INT 11 51
EXH 58 10
SPECS FOR CAM INST. @ 110 CENTERLINE
INT EXH
DURATION @ .050 242.00 248.00
LOBE LIFT .360 .375
LOBE SEPARATION 112.0
ROCKER ARM RATIO 1.60 1.60 REQ SHIP DATE
NEED OPINIONS....Truck will see some daily driving and some track time.I have a dp system on intake pilled for 150shot also.Thanks.
Old Mar 22, 2003 | 06:33 PM
Josh-'04 GTO's Avatar
That's a pretty hardcore cam, but with the M6 you should be fine. Should make some great power. As long as you don't have emissions testing....
Old Mar 22, 2003 | 07:20 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
THATS A BIG FAWKING CAM
Old Mar 22, 2003 | 10:04 PM
Im a state inspector so Ive got that handled.
Old Mar 23, 2003 | 07:52 AM
Anyone have anything else to add here?
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
carl.froehlich
Mar 13, 2015 12:38 AM
alliance12364
Mar 6, 2015 04:39 PM
