any tricks to remove a stubborn bleeder screw?
Old Mar 22, 2003 | 05:44 PM
JoshGuitar's Avatar
Angry any tricks to remove a stubborn bleeder screw?
my right rear brake bleeder screw will not move. I soaked it with WD40 for a looong time, multiple "coats", and all my wrench did was strip the head. I tried vice grips, clamped down really tight, all they did was strip it. It's like it's on there real tight, but the metal's too soft for me to give it enough torque to unscrew it. I bought a replacement screw but it ain't doin me any good til I can get the old one off. Any bright ideas?
Old Mar 22, 2003 | 05:49 PM
mehoffz24's Avatar
if i was you i would get a better penitrant then wd40. go to the store and get seafoam DEAPCREAP, or liquid wrench, once you soak it get a special socket for removing bolts with rounded off heads. good luck, sorry if im not more help
Old Mar 22, 2003 | 05:51 PM
Try PB Blaster.
Old Mar 22, 2003 | 06:30 PM
96ltz's Avatar
If youv'e already rounded it off you can try an ez out on it or I have gotten them lose with vice grips before
Old Mar 22, 2003 | 06:48 PM
Mikey97Z's Avatar
cut a slot in it so you can use a big screwdriver
Old Mar 22, 2003 | 07:23 PM
SilverStreak's Avatar
Lightbulb
Yeah, i've had a really stubburn one before, i soaked it in PB Buster and tapped it for like an hour to let it work in, then i filed down each side so i turned it into a box(another 30 mins) then me and 2 other people clampped down vice grips on it so hard that it left brusies in my hand.... then it stripped.. LOL. So i finaly took it off and the thing that finaly got it to break loose was clampping the end of the bleeder screw in a vice and spinning the wheel cylinder. hope it helps. good luck.
Old Mar 22, 2003 | 08:38 PM
1981zzz's Avatar
heat it up with a torch then spray wd40 and repet 2 to 3 times then tap it with a small hammer works for me every time
Old Mar 22, 2003 | 10:14 PM
DjArcadian's Avatar
I replaced mine with some screws that you can use an allen wrench with. Makes removing them much easier IMO.
Old Mar 23, 2003 | 12:30 AM
dave1w41's Avatar
Keep this in mind the next time you toss out those little rubber or plastic covers that go over the bleeder screws. With those on, even cars that have well over 100,000 miles on them don't have stuck bleeders.
Anyway, heat and lubrication are what is going to do the trick here. You should be able to heat it quite a bit and not do any damage. After all, it is a brake caliper, it is designed to take some heat. Use a propane or MAPP torch to heat the screw directly and spray it with Cyclo Break Away or PB Blaster. Toss that WD-40 right in the trash where it belongs. I don't know what that stuff is good for, it is crappy lube and it can't protect worth a chit either. You might as well be using #2 diesel fuel as a lubricant. Heat and lube several times -
BE CAREFUL NOT TO START A FIRE!!!!!!
Grab it with a pair of Vise Grips while it is still hot after the third or fourth application. It should come out. If it does not, time for a new caliper, some of them can't be saved.
Old Mar 23, 2003 | 07:01 AM
Don 97 SS's Avatar
Originally posted by shoebox
Try PB Blaster.
I discovered this stuff about a year ago upon a friends recommendation. It by far is the best penetrant that I have ever used. That stuff comes in a weirdly labeled spray can, but definitely works well.
Old Mar 23, 2003 | 07:08 AM
joeSS97's Avatar
Always use a 6 point socket when possible,you wouldnt have rounded it off.I know its not much help now,but next time.Heat it up good and as mentioned,vise grips or easy out.Good luck.
Old Mar 23, 2003 | 09:01 AM
gb95zconv's Avatar
Yeap, like said before heat and penatrating oil. My favorite is Rust Eater......works as good as or better than PB Blaster. Both are good stuff.
Old Mar 23, 2003 | 05:08 PM
JoshGuitar's Avatar
I used PB blaster (got it in my eye too ), but couldn't get ahold of a torch. Cops came by and said I couldn't have my car on jackstands in front of my house any longer so I hadda give it up . I swear, I don't think anyone ever bled the brakes before I got this thing...the other screws were fine but I don't think this thing's ever been cracked loose...
Oh well, the rest of the brake system is bled, it'll do for now, maybe one of these days when I'm bored I'll borrow a torch or pull the caliper and try the vice technique...
Old Mar 23, 2003 | 08:53 PM
gb95zconv's Avatar
What a load of BS.....you weren't on the street were you? With all the crime going on out there looks like they wouldnt bother someone trying to work on thier car.
Old Mar 23, 2003 | 09:27 PM
Sheesh , the mod police.
