Aiming TA headlights
Old Mar 22, 2003 | 10:15 AM
StupidLT1TAGuy's Avatar
The headlights on my car are shifted toward the passenger side, and only light up right in front of the car...No distance to them whatsoever. They're as bright as a headlight should be, just out of alignment. How do I get them aligned? Are there screws to do it?
I guess there's a reason I put 'stupid' in my screen name...
Old Mar 22, 2003 | 11:54 AM
1994TransAm's Avatar
you are correct.. these headlights use screw. i think you must do this...
- park the car 20 feet away from a wall or garage door and open
the hood, make sure your head lights are on.
- Once the headlights are up, remove the 2 or 3 screws on the
sides of the headlight housing, these screws attach the black
side cover to the assembly. after you remove the black cover
you will see the 2 screws that adjust the headlights.
- now you can aim them
good luck, and remember any damage you cause is not my fault
Greg88
Sep 20, 2015 07:14 PM
Henson071
Sep 18, 2015 04:01 PM
jackpawt883
Sep 10, 2015 08:53 PM
Aug 17, 2015 09:50 AM
Henson071
Aug 4, 2015 09:32 AM
