i got a 52mm tb
Old Mar 22, 2003 | 07:36 AM
besz28's Avatar
i got a 52mm tb
hey guys i can not believe it i just won a ported stock tb to 52mm for 88.00 dollars see ya
Old Mar 22, 2003 | 01:54 PM
Josh-'04 GTO's Avatar
Uhh...my local machine shop did mine for $90.00 complete.
Old Mar 22, 2003 | 01:59 PM
RamAir95TA's Avatar
Old Mar 22, 2003 | 02:47 PM
Euclid's Avatar
or you can borrow a friends dremel tool and do it yourself...
Old Mar 22, 2003 | 02:59 PM
rabid_dog's Avatar
Gee uh, wouldn't a die grinder be easier?
Porting the throttle body eh? Sounds pretty sweet. I'm kind of a head porting freak, (I don't think I've ever built an engine AND left the heads unmolested). Anyone have any good links on best ways to open up the TB via grinding?
And I do mean BEST ways, any idiot can dive in and take out material. Are there any things to watch for/keep in mind? Anyone reading this ever done it themselves?
Heh heh, I've got goosebumps just thinking about it. (Yup, call me a crazy car nut).
Old Mar 22, 2003 | 03:04 PM
Euclid's Avatar
you can take an old TB gasket, place it on the back of the TB (where the gasket's supposed to go) then spray paint it red. This will draw out exactly 52mm for ya
Then grind it all down (using the red paint as a guide), polish it up and voila! you're done.
If you want, it's usually good to polish up the butterfly blades as well. They have a few obvious restrictions and thier finish is quite restrictive as well... just make it so you can see yourself in all of your work when you're done
Old Mar 22, 2003 | 03:39 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Originally posted by RamAir95TA
x2
Old Mar 22, 2003 | 03:45 PM
Grease's Avatar
Just a question for all you who've ported throttle bodies.
Do you use the same throttle plates? If you do, whats the point? You can port the throttle body to 900mm but if you still have the stock throttle plates it will still be a 48mm throttle body
Old Mar 22, 2003 | 03:55 PM
Not Quite!!! You need to have bigger throttle blades made up as well. So not only will the machine shop ACCURATELY bore to 52mm but you will have the proper size blades as well.
Old Mar 22, 2003 | 04:34 PM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
Why not just buy a new throttlebody? It seems easier to me. No guesswork. Just my 2 cents.
Chris
Old Mar 22, 2003 | 06:00 PM
Chris
New throttle body=$300.00 +/-
Machined stock throttle body=$90.00 +/-
By the way, there is no guesswork!
Old Mar 22, 2003 | 06:01 PM
Grease's Avatar
Okay, I was under the impression people just ported/hogged out the throttlebody but never changed the throttle plates
Old Mar 22, 2003 | 06:08 PM
I think just hogging out the bores messes up the idle and makes it hard for the IAC to keep proper idle control since there is so much air leakage past the stock blades. Besides, for less than $100 it comes out perfect, and you don't need to spend $300 on an aftermarket one.
Old Mar 22, 2003 | 06:21 PM
AlexBarabas's Avatar
Add another $50+ for bling bling chroming...
Old Mar 22, 2003 | 06:45 PM
NOMAD's Avatar
Cool
Yes, you have to buy new blades or your gonna have a 2mm gap in the top and bottom of the throttle body. No, you can't do it with a dremel, die grinder, hole saw, etc.
It takes a little research to get these things accurate. IAC holes need to be "adjusted" and such. The throttle shaft needs to have the sides cut so the bigger blades will fit also.
Make sure you actually got a 52mm, there are plenty of fakes out there
-Shannon
