Just weighed the Z
Old Mar 21, 2003 | 02:51 PM
tomslawsky's Avatar
Just weighed the Z
2001 Z: Options are Rear window defrost, Monsoon stereo, MN6/Hurst. That is all. I have a borla cat back and Sub frame connectors and BMR STB. The weight was taken with everything in it (including spare and jack), NO one in the car and the low gas light just poped on about 5 miles ago. And the weight is......
3360lbs I think the scale is correct because I am 160 lbs and when I got in, it went right up to 3520lbs. So, what do you think? Light, heavy or right where I should be. Remember...basically stock with different cat back, SFC and strut tower brace with about 2.5 gallons of gas in her.
Old Mar 21, 2003 | 02:57 PM
Wease's Avatar
Smile
That seems about right. With about 100 pounds of weight removal, my Formula (without me in it) with a 1/4 tank of gas weighed 3290...
Old Mar 21, 2003 | 03:49 PM
camaros_4_lfe's Avatar
what is the diff between a 97 ss and 98 ss weight wise??
Old Mar 21, 2003 | 04:00 PM
Camaro ChriSS's Avatar
The LT1 engine (the main weight difference, if I recall correctly) is about 50 pounds heavier in weight, so for two cars with the exact same options, the 97 will be slightly heavier.
Old Mar 21, 2003 | 04:22 PM
venomcure98's Avatar
well, I think body weight is personal preference. Are you where you think you should be?? lol jk
Yeah that sounds right for that car but i did think it was a little bit heavier than that.
Old Mar 21, 2003 | 06:29 PM
96SFLZ's Avatar
I guess that sounds about right for a hardtop w/ the 1SC option.
Good to know, I'd imagine that I should be right around there...maybe 15-20 lbs. more. I'll have to weigh it next time I'm at the track.
Old Mar 22, 2003 | 09:21 AM
psychocabbage's Avatar
Yup.. mines a tad bit heavier but I cant own a Z without T-Tops..
Other than the T-Tops, I have the same options as you.. all standard and just the hurst and rear defogger..
3490 with 12.5 gallons of gas (est..)
all my usual stuff in car (helmet and tools(about 5 lbs worth) and spare and jack of course.. so I am happy with its svelt weight..
Old Mar 22, 2003 | 01:28 PM
stik6shift98's Avatar
where can u weigh them at.....the local track around here doesnt have one....
i was thinking of just goin to the truck stop???is that possible
Old Mar 22, 2003 | 06:19 PM
SFB767's Avatar
Re: Just weighed the Z
3360lbs
That seems a little light. My car is loaded and is an A4 and it weighs around 3,500 lbs., give or take a few pounds. Look inside your driver's door jamb for the car's GVWR. Take that number and subtract it from the maximum weight the vehicle can carry (also listed on the door jamb), and that's how much your car weighs.
Old Mar 22, 2003 | 06:22 PM
SFB767's Avatar
Yeah, that's possible. When I was moving out of my dorm and getting ready for the trek home, I weighed my dad's truck with EVERYTHING I crammed in there to see if I was over GVW, it cost me $6.00 and it tells you how much weight is on the drive axle and the steer axle.
Old Mar 22, 2003 | 09:20 PM
except i want to take my camaro there......would they look at me weird
Old Mar 22, 2003 | 11:01 PM
TransAmLS1's Avatar
Go to a grain elevator and ask them if you can weigh your car. Since they are not to busy this time of year I doubt they would care.
Old Mar 22, 2003 | 11:04 PM
lmao
where would i find one
Old Mar 22, 2003 | 11:05 PM
TransAmLS1's Avatar
lmao
I am serious, just get out of the big town and you will find one in no time.
Old Mar 23, 2003 | 12:19 AM
tainted's Avatar
I was telling a friend that my 00 SS weighed about 3300 lbs. He said "No, check the door, it will tell you the car weight on it."
I check it, and it says 4200. WHAT THE F*CK!? That 01' z just weighed in at about 3300. What's the difference? Or is the door lying?
