where and how to check for vacuum leaks?
Old Mar 21, 2003 | 01:09 PM
bachehbad's Avatar
Ok i just want to make sure i don't have any, but i have no idea what to look for!! can anyone here help me out, all information would be much apreciated, or even if you guys could post a web page about this!!!
Again any extra info that some1 else hasn't added i could use, thnx guys!
Old Mar 21, 2003 | 01:15 PM
atljar's Avatar
Start on the intake manifold. It has tons of little hoses on it. Make sure they are all on, and snug. Follow these hoses and make sure they are tight on the other end.
Now onto the intake tract. Make sure the filter is firmly attached on the tube, make sure the MAF is sealed all the way around on filter side, and elbow side. Now this is the hard one. Make sure the elbow is connecter around the TB. IT might look connected up top, but the bottom is a PITA to get seated properly. Might not even be noticable unless you take off the elbow and reinstall.
EDIT: forget the MAF part, you dont have one on a 93
Old Mar 21, 2003 | 01:56 PM
Mtrhds94Z's Avatar
Re: where and how to check for vacuum leaks?
On the radiator support, there's a diagram of all your vacuum hoses and routing, etc...
That's a good place to start...
Old Mar 21, 2003 | 02:32 PM
93Z286Speed's Avatar
will a vacumme leak cause a loss in power?
Old Mar 21, 2003 | 03:27 PM
bachehbad's Avatar
yea thats another thing i was wondering, do vacuum leaks cause performance loss??
Old Mar 21, 2003 | 03:34 PM
Hal Fisher's Avatar
When the engine is COLD, spray carb cleaner around the intake manifold and other possible vaccum leak areas. If the idle increases you've found a leak.
Or, you could use something that is NON-Flammable which would cause the engine to chug or die a little. I would say the non-flammable approach is safer so maybe something like Nitrogen spray would be better.
Either way if the idle rate changes you've found a leak (actually an opening that is sucking in air).
Hal
Old Mar 21, 2003 | 11:25 PM
but but but but do i loose performance..
i know my vac lines around my TB are all dry rotted..
Old Mar 21, 2003 | 11:51 PM
Wild1's Avatar
I haven't seen the vacuum junction on the Radiator Support. I'll be under the car tomorrow... where is it located specifically?
Rog's Avatar
Rog
yes yes yes yes you do lose performance with a vacuum leak. How much lost performance depends on how much vacuum is lost.
Old Mar 21, 2003 | 11:59 PM
They were talking about a diagram for vacuum hose routing on the radiator cover.
There is a hose that goes by the battery to the vacuum tank, though. Mine had a hole in it from rubbing on the metal where it makes the turn. It was causing my IAC counts to be way low. See my Tech Page for vacuum connections.
Old Mar 22, 2003 | 12:15 AM
Wild1's Avatar
LOL... that explains why I didn't see the diaphram. Yes, there is a diagram there. It's late after a long day... sorry guys. lol
Old Mar 23, 2003 | 07:14 PM
i think i need to check all my vacume lines... is there anyway i can test this stuff?
Old Mar 23, 2003 | 07:35 PM
dreamer1q's Avatar
Hal
BINGO....exactly how I have done it for years. Use a cleaner that is flamable...it will clean the areas sprayed and increase the idle as well. Two birds, one stone.
Q
Old Mar 23, 2003 | 08:12 PM
Easy to do with a Mighty Vac or similar hand held vacuum tester.
Old Mar 23, 2003 | 09:14 PM
hmmmm how? hahaha
