Brake Help please
Old Mar 21, 2003 | 12:59 AM
corkss's Avatar
Brake Help please
I took my two front wheels off, then the calipers to paint them red . Drivers side was good, but when I got to the passenger side, the rotor was there just "dangleing" the onnly thing holding it on was the lugnuts!!!!
Whats the problem here, what should I do!
TRhanks, Matt
Old Mar 21, 2003 | 01:19 AM
viperkiller's Avatar
id rather see a person not know and ask then not know and tear somthing up but thers no problem thay have floating rotors if you look at the other side it should be the same way the tire holds the rotor in place
Old Mar 21, 2003 | 01:26 AM
Van5150's Avatar
Damn, why couldnt I have had rotors that begged to come off when I changed them. Took me a hour and a torch to heat them up to get them off,.
Viperkiller, is absolutely correct, there is no problem, thats the way they should be, it must be your lucky day, is it your B-day ?
Old Mar 21, 2003 | 01:30 AM
Draco's Avatar
yep once the tire is torque down those rotors are not going to go anywhere.
Old Mar 21, 2003 | 08:03 AM
Z-Attitude's Avatar
The rotors have detent washers on them to hold them in place on the assembly line. The first thing you do is tear them off with side cutters when you first remove a rotor. Nothing wrong without them, as stated the wheel holds them in place. Later>>>>>>>
Old Mar 21, 2003 | 09:58 AM
corkss's Avatar
Van5150
LOL
My B-day is in couple days!
Thanks for your help guys, i was worrieda bit for a sec.
Matt
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
cohopefull
Sep 8, 2015 03:22 PM
maverickmk
Sep 1, 2015 09:17 PM
