Why use a Adjustable Fuel Reg?
Old Mar 21, 2003 | 12:20 AM
Van5150's Avatar
Why would you install a adjustable fuel reg if the PMC is gonna compensate for any change you make to anyhow? - Yeah, I'm sure for some of you this is a noob question, sorry.
Old Mar 21, 2003 | 01:07 AM
96z's Avatar
96z
Most who know what you mentioned dont. It does seem to work though on the 93's and with an aftermarket "control system" such as FAST..
Old Mar 21, 2003 | 01:18 AM
Van5150's Avatar
It does what ? lol ,,.
Old Mar 21, 2003 | 01:20 AM
Draco's Avatar
at WOT the adjustable FPR will work as intended, increasing the fuel flow through the injectors thanks to the higher pressure. You can use it to lower your injector duty cycles at peak power levels.
Unless you are running over at least 320 rwhp with stock injectors you will not likely benefit from this added fuel.
Old Mar 21, 2003 | 01:22 AM
Van5150's Avatar
Ok, will the Adjustable Fuel Regulator fix the problem associated with black smoke (rich) some people see with wide open throttle ?
Old Mar 21, 2003 | 01:26 AM
Draco's Avatar
If you lower your AFPR below the stock pressure, the PCM will compensate to keep the stoich 14.7:1 A/F ratio under part throttle.
Under WOT, the PCM will not seek this stoich ratio, so reducing the pressure will reduce the amount of fuel flowing through the injectors, leaning the mixture.
So yes, this could be used to reduce the black smoke (due to richness) at WOT.
Old Mar 21, 2003 | 01:27 AM
96z's Avatar
96z
Not neccesarily, could be a bad O2.
What is it about AFPR you want to know? I thought I anwsered your question.
Old Mar 21, 2003 | 01:29 AM
Van5150's Avatar
Draco, I see you post here all the time, you really do a good job with your posts.
You said that we could use the Fuel Reg as a way to adjust for black smoke, it almost sounds like you know a better way, or something that should be looked at.
Is there ?
Old Mar 21, 2003 | 01:36 AM
96z's Avatar
96z
I said that we could use the Fuel Reg as a way to adjust for black smoke, it almost sounds like you know a better way, or something that should be looked at.
Is there ?
Using an adjustable fuel regulator is not an anwser to your problems. LT1s do run rich but not all blow black smoke like your talking about... toning down the fuel pressure isnt a good fix IMO. The PCM is going to learn the change and change the pulse widths of the injectors anyway...bringing you right back to where you started.
Old Mar 21, 2003 | 01:45 AM
Van5150's Avatar
I agree with you 96z. From what I understand(very little) the PMC will after a little time relearn and adjust. Do we need an adjustable fuel regulator ?
Old Mar 21, 2003 | 02:01 AM
Dr.Mudge's Avatar
Hey Eddie
An adjustable FPU works for tuning on 93 cars, and plenty of others, but 94+ cars will compensate. Not alot of reasons to have one other than going for a specific fuel pressure for whatever reason one might have.
I am going to use a boost sensing fuel pressure gauge for my turbo car, old fargin 1982 computer, not many other ways to fix these problems on older cars that you cant really rip into the computer to fix.
Old Mar 21, 2003 | 02:03 AM
96z's Avatar
96z
No.
Old Mar 21, 2003 | 02:08 AM
Van5150's Avatar
Eddie ,.,. lol Dr.Mudge.
Now I see what 96Z was saying in his 1st post. I guess I'll sell my '95 camaro and get a '93 so I can use the adjustable fuel regulator. Thanks everyone.
Old Mar 21, 2003 | 02:16 AM
Dr.Mudge's Avatar
Are you fargin serious???
Dude, get Tunercat and a cheap laptop!!!
You have the "perfect" year LT1 The car should not be running that rich unless you have a problem, like bad O2/CAT etc. You can download Freescan and diagnose your problems, which is what I did with my 94, works great.
http://www.andywhittaker.com/ecu/ecu_software.htm
Got my cable from Steve, www.wotelectronics.com
Adjustable FPU is nothing but a bandaid or workaround for those that can't tune with the computer, be gratefull IMO that you have such an awesome EFI setup. Adjustable FPUs are for people like me with old old cars or lazy bastardos/cheapos who dont want to tune the car "properly", JMO of course.
An adjustable FPU will affect the whole range and that is a problem, these cars are rich only at WOT and within a certain MAP range, otherwise your car should not run rich unless something is wrong, which can be fixed!
Old Mar 21, 2003 | 02:28 AM
Van5150's Avatar
Ut oh.,, my bad,. It was just a joke,. sorry,. lol
Fastbird93
Apr 9, 2016 07:01 PM
thenewkid
Apr 12, 2015 07:42 PM
Cam's maro
Jan 30, 2015 09:21 PM
thenewkid
Nov 27, 2014 09:41 AM
F(ast)-body
Feb 26, 2003 09:05 AM
