craigffb
03-20-2003, 07:08 PM
What all do you need to put a blow down tube on, and will any one work..ie NX, NOS and so on?:confused:
Blow down tube...craigffb 03-20-2003, 07:08 PM What all do you need to put a blow down tube on, and will any one work..ie NX, NOS and so on?:confused: stik6shift98 03-20-2003, 07:18 PM what kit do u have....why not just get the one from the brand kit u have...i have nx and have the nx one it was simple to install craigffb 03-20-2003, 07:27 PM Originally posted by stik6shift98 what kit do u have....why not just get the one from the brand kit u have...i have nx and have the nx one it was simple to install I have a NX kit, but I would have to order it from some place when I could just pic up a NOS one from one of the parts stores here on the Island. But do I need the "Blow-off Cap" as well? How does It hook up?? snow2000SS 03-20-2003, 07:59 PM The NOS one would not work very well it is a 90 degree and belive you need a 180 degre to fit the NX bottle. craigffb 03-21-2003, 12:38 AM Originally posted by snow2000SS The NOS one would not work very well it is a 90 degree and belive you need a 180 degre to fit the NX bottle. OK, got it. It's best to get the NX one. But do I need to get the Blow-off cap?:confused: stik6shift98 03-21-2003, 09:21 AM Originally posted by snow2000SS The NOS one would not work very well it is a 90 degree and belive you need a 180 degre to fit the NX bottle. oh yeah you do need the 180 one... craigffb 03-21-2003, 10:52 AM Originally posted by stik6shift98 oh yeah you do need the 180 one... Ok, I need the NX tube. Do I need to get the Blow-off Cap for the tube to work, or will the bottle just blow up in the trunk???:confused: snow2000SS 03-21-2003, 11:12 AM Not sure not real up on the NX stuff try giving them a call JodyJ 03-21-2003, 11:40 AM Yes, you will need the Blow Off Valve. This is what it looks link: http://jody.dltechnologies.com/shared/Nitrous/BlowOffValve.jpg The tube that came with my Gen II kit was short, so I went to the local hardware store and purchased 3ft. of 1/2" aluminum tubing. Custom bent it to fit in the truck and out the rubber grommet on the bottom of the spare tire area. I used the same fittings from the original tube and used a flaring tool to flare out the ends and that's it. Total cost was $6 for the tubing. Hope this helps. Jody J. Ed Blown Vert 03-21-2003, 11:43 AM You need to change the the blowoff cap so you can attach the blowoff tube. Don't forget to change the Pressure Relief Disc. craigffb 03-21-2003, 11:58 AM Thanks. Now I know what I need to get. :D stik6shift98 03-22-2003, 03:10 AM Originally posted by craigffb Thanks. Now I know what I need to get. :D hope everything works out good for you:D Z28ROC 03-22-2003, 12:48 PM Don't overtighten that fitting when you put the new one on. It will damage and weaken the disc. Also make sure the bottle is completely empty before changing them out. kirschman 03-22-2003, 05:22 PM get a bulkhead fitting for the floor. Screws to the tube, makes it alot cleaner look snow2000SS 03-22-2003, 11:25 PM Z28ROC good point. I see alot of saftey disca blow becuase they are over tightened. We usually recomend hand tigh then 1/8 turn. Then if it leaks tighten till it stops leaking and you're done. | ||
